Results 1 to 10 of 13
Thread: Pipe elbow going wrong direction
    AUGI Addict Jrobker's Avatar
    2005-08
    11,000 feet atop a chute
    1,001
    Default Pipe elbow going wrong direction
    I would like to know if this is just an isolated instance or if everyone deals with this.
    This is a pipe reducing short tee (OOTB).
    Does anyone know why it models the fitting backwards.
    Horizontal pipe
    If I model from the top of the pipe it assumes the flow to go right.
    If I model from the bottom of the pipe it assumes the flow to go left.
    Vertical pipe
    If I model from the right of the pipe it assumes the flow to go down.
    If I model from the left of the pipe it assumes the flow to go up.
    Once those down syndrome fittings are in, forget about modifying them.
    I have to mirror the correct one to get it on the other side.
    See attached
    JR
    "Keeping my view range hopeful."
    I could stop if I wanted to Simon.Whitbread's Avatar
    2003-06
    London, UK
    351
    Default Re: Pipe elbow going wrong direction
    Quote Originally Posted by Jrobker View Post
    ...down syndrome fittings ...
    WTF? - Nice turn of phrase? I think not
    Simon Whitbread
    Revit Technical Specialist, Autodesk
    about.me/simonwhitbread
    "The distance the shotput goes, depends upon the effort that you PUT INTO IT"
    AUGI Addict matt__w's Avatar
    2002-06
    North Central CT
    1,108
    Is your pipe connected to a source (I.E. a pump)? What if you connected the pipe to a source then added the fitting? You would think it would/should be smart enough to know the direction of flow based on the equipment that the pipe is attached to. Just thinking out loud.
    Matt
    2004-06
    Port Moody, BC
    348
    Do the fittings have an angle parameter that you can change to get them to look correct again, for example a parameter that is set to 135 degrees that you can change to 45 degrees?
    2005-08
    1,001
    Quote Originally Posted by mattw View Post
    It has no affect. As you might not have noticed I have the pipes capped. I doesn't matter if they are connected to equipment/in systems, routing solutions even does it wrong.
    Quote Originally Posted by drewj
    It does. I have to disconnect the branch line first, than it allows me to change the angle and than flip it. After I do this and reconnect/remodel the branch it goes back to the original 135 degree.
    Quote Originally Posted by Simon.Whitbread
    Wha....
    JR
    2004-06
    Port Moody, BC
    348
    I looked at the fitting (2009 part I think, discontinued in later libraries)
    seems like you may need to change how you make this intersection, for example, if you trim the incoming branch and the main, then change the resulting elbow to a tee with the addition grip this seems to work...
    Not a great answer regarding that particular fitting and its issues, but sometimes its best to just ignore why Revit doesnt do something and work with how it can model it for you!!
    Example image attached...
    EDIT: Image should say change into tee not change into elbow
    Good luck
    2005-08
    1,001
    That doesn't work.
    There is something wrong with this tee.
    I'm going to go through and revamp.
    JR
    2006-10
    236
    That happens all the to me all the time. That fitting seems to prefer that impossible configuration. I have all but given up on finding a "fix". I keep hoping "Maybe The Next Release!"
    8
    I ran into the same problem, and at least from what my intent was, it has to do with trying to make a fitting work that wasn't intended to be used that way. Like the OP, I wanted to connect with a "wye" fitting, but the settings for the pipe types are not extensive enough to allow you to set a default "wye" connection, and "wyes" are not available to select from the "tees". The san tee will allow that "wye" type connection, but as the OP shows, it doesn't always work.
    We purchased some third party families a while back and one of the things I noticed is that when selecting the default "tee" for a pipe type, the third party "wye" fittings were available to choose from. Problem solved.
    I don't know enough about family creation to say for sure, but it appears that the OOTB "wye" fittings might be able to be modified to be able to show up with the "tee" fittings, so you can select that connection by default for that pipe type.
    2005-08
    1,001
    You can. You just have to go to the Family Category and Parameters of the family and change the part type to a tee instead of wye. Now you have that option as a fitting in your Pipe Props.
    This isn't the issue. The issue is the flow direction. The "WYE" works only in 1 direction.
    JR
  1. 2014: ACAD MEP 2013/2014 Wrong elbow area calculation in bomtables
    By jmb_bg392861 in forum AMEP General
    Last Post: 2014-06-04, 05:41 AM
  2. Revcloud in wrong direction
    By mvsawyer in forum AutoCAD General
    Last Post: 2010-06-08, 07:07 PM
  3. Pipe elbow not being created
    By mattw in forum Revit MEP - General
    Last Post: 2010-05-21, 04:04 PM
  4. Pipe Elbow Size
    By phil.pleiss in forum Revit MEP - Families
    Last Post: 2010-02-11, 04:13 PM
  5. Pattern wrong direction
    By Chris DiSunno in forum Revit - Rendering
    Last Post: 2005-08-11, 03:27 PM
