Originally Posted by
MHultgren
Hello Liesl,
Did you create a 'Style' for your surface display? Once you do that, then switching from one display 'style (e.g. Showing contours at 1' and 5' intervals) to another is a matter of changing the style name in the Surface Properties.
Another method is to use the Analysis method if you are looking for Slope arrows or ranges, elevation banding, etc... but you will still need to have a 'style' defined beforehand.
I deleted this answer from your other post and moved it to here.
I will edit that post so you don't get multiple answers. That way it makes it easier for others to find the answers when you post a question in one place instead of two or three. (This is known as "cross-posting" and it makes it difficult to find the answers easily.)
