Thread: Revit fail.
    Default Revit fail.
    When I touch a element Revit 2011 says:
    Element 344449(not always the same number/element) became corrupt at some time before this session. ), what can I do about it.
    When I so save recover, revit says:
    there is not enough space on drive C: to create the temporary files that revit needs. Either free up space on this drive, or redefine windows user variable TMP to be a folder another drive with more space.
    What Can I do about it ?
    2010-09
    21
    Default Re: Revit fail.
    Quote Originally Posted by Mikkelebrodersen View Post
    I used to get the same error when I ran out of memory using 2011. Sometimes I was able to save when I shutdown all other programs running in the background....but most times I had to crash Revit......
    I think you can blam the bad programing of 2011.
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    Yeah, I used to get that quite often using 2009 even...Haven't seen it since upgrading to Win 7 64bit....
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
    I found out a solution.
    If u have the same problem, try to "save as" your file with another name.
  1. Revit files always fail to transmit over the FTP
    By Wagurto in forum Revit Architecture - General
    Last Post: 2011-03-30, 10:46 PM
  2. 3D SUBTRACT fail
    By musunya in forum AutoCAD General
    Last Post: 2010-04-04, 03:32 AM
  3. AMEP instant fail in 3D
    By Beancud in forum AMEP General
    Last Post: 2008-07-03, 08:45 PM
