Results 1 to 7 of 7
Thread: Need Help Understanding Attached Lisp
    2005-11
    Daly City, Ca.
    40
    Default Need Help Understanding Attached Lisp
    I need help understanding this lisp. It was created for me by an augi member but i can't recall who and when that was. Now our block has changed and the lisp is not working properly.
    The lisp is suppose to bump all the revision line attributes up 1 to make room for a new line. We now have 10 lines of revision, each line has 10 attributes. The first line stays as is, the second line gets bumped out and replaced by the 3rd line and so on and so forth leaving the last line empty for the new revision information.
    If someone can decipher and translate that would be helpful. I'd like to understand and hopefully be able to update it as necessary.
    Thanks for the help. I've attached a couple of files, the old border and the new border. We removed 22 lines of attributes which i think messed w/ the calculations.
    Here's the lisp
    (defun C:BMP (/ intBase intItem intRecord lstOfSublists ssSelections)
    (if (setq ssSelections (ssget "x" (list (cons 0 "insert")(cons 2 "100-G13-BDR-E-FP")(cons 410 (getvar "ctab")))))
    (progn
    (vl-load-com)
    (vlax-for objItem (vla-get-activeselectionset
    (vla-get-activedocument
    (vlax-get-acad-object)))
    (setq lstOfSublists (getattributesublists objItem)
    intBase 17
    intRecord 7
    (repeat 10
    (setq intItem 11)
    (repeat 12
    (if (<= intRecord 14)
    (vla-put-textstring (nth 2 (nth (- (* (1- intRecord) 12) intBase intItem) lstOfSublists))
    (vla-get-textstring (nth 2 (nth (- (* intRecord 12) intBase intItem)
    lstOfSublists
    (setq intItem (1+ intItem))
    (setq intRecord (1+ intRecord))
    (defun GetAllAttributes (objSelection /)
    (if (= (type objSelection) 'ENAME)
    (setq objSelection (vlax-ename->vla-object objSelection))
    (if (vlax-property-available-p objSelection "hasattributes")
    (if (= (vla-get-hasattributes objSelection) :vlax-true)
    (vlax-safearray->list
    (variant-value
    (vla-getattributes objSelection)
    (defun GetAttributeSubLists (objSelection / lstAttributes)
    (if (setq lstAttributes (getAllAttributes objSelection))
    (progn
    ; (princ lstAttributes)
    (mapcar '(lambda (objAttribute) (list (strcase (vla-get-tagstring objAttribute))
    (vla-get-textstring objAttribute)
    objAttribute
    lstAttributes
    (princ)
    I could stop if I wanted to pbejse's Avatar
    2010-10
    395
    Default Re: Need Help Understanding Attached Lisp
    I would've help you only if i can open the file....The problem is fairly easy
    W'ere still stuck with Autocad 2009 though
    2005-11
    Daly City, Ca.
    40
    I've attached a 2007 version. Thanks for the help.
    2010-10
    395
    Quote Originally Posted by sumulong788473 View Post
    (progn
    (vl-load-com)
      temp lstOfSublists
    intBase 17
    intRecord 7
    (repeat 10
    (setq intItem 15)
    (repeat 10
    (if (<= intRecord 15)
    (vla-put-textstring (nth 2 (nth (- (* (1- intRecord) 10) intBase intItem) lstOfSublists))
    (vla-get-textstring (nth 2 (nth (- (* intRecord 10) intBase intItem)
    lstOfSublists
    (setq cnt 18 rev_nm (strcat "REFER TO PREVIOUS FILES FOR REVISIONS 0 THRU " (itoa (-
    	    	(atoi (vla-get-textstring (nth 2 (nth 29 lstOfSublists)))) 1)))
    	    	as_is
    	  	(mapcar '(lambda (p)
    			   	(vla-put-textstring (nth 2 (nth (setq cnt (1+ cnt)) lstOfSublists)) (eval p)))
    				  	'("-" rev_nm "" "" "-" "" "" "-" "-" "-")) cnt_ 0)
    (variant-value
    (progn
    objAttribute
    lstAttributes
    (princ)
    Try this with your new border and tell me what you think
    EDIT: i overlooked the 1st Rev (i automate the number to match the 2nd line rev no.)
    	    	as_is
    Past Vice President peter's Avatar
    2000-09
    Honolulu Hawaii
    574
    Since these are functions that I created, I can explain what they do.
    The function accepts one argument that is either an entityname or a vla-object of a block with attributes and returns a list of attribute objects. There are some error checking conditionals to make sure the object has the hasattributes property and is true.
        (variant-value
    Without the error checking and assuming you are passing a block vla-object you can rewrite it thus and it will return a list of attribute objects.
    (defun GetAllAttributes (objSelection)
     (vlax-invoke objSelection "getattributes")
    Peter
    AUGI Volunteer
    2000-09
    Honolulu Hawaii
    574
    This function accepts an entity name or vla object of a block and returns a list of sublists. Each sublist contains the uppercase tagstring, textstring and the attribute object of each attribute.
    Peter
      (progn
                       objAttribute
                lstAttributes
    AUGI Volunteer
    2010-10
    395
    Smile Re: Need Help Understanding Attached Lisp
    Quote Originally Posted by Peter View Post
    Peter
    Hope I did justice with your orignal bmp.slp
    Thank you for explaining the codes to the OP
  1. Understanding Lookup
    By bcole.200021 in forum Dynamic Blocks - Technical
    Last Post: 2009-04-06, 09:05 PM
  2. Replies: 2
    Last Post: 2007-05-11, 11:25 AM
  3. Replies: 0
    Last Post: 2007-04-30, 05:05 PM
  4. Is it possible to draw attached image via a LISP routine?
    By BRENDA_GZZ_GOMEZ in forum AutoLISP
    Last Post: 2007-04-16, 09:00 PM
