Thread: Purlin releases and deformations
    2009-10
    32
    Default Purlin releases and deformations
    Hi,...
    ...I'm working lately on a workshop project, 40m wide, 150m long, 17m height. It's a classic rigid steel frame construction.
    The problem as you can see in the attached pictures is the excessive deformation in the first and last frame along the local y axes. As you can also see from the attached picture there are „xxxfff“ releases of purlins and wind braces (simply supported, just like I want it). (the first two pictures)
    The problem seams to vanish when I change the adjacent purlins releases to „xxxxxx“. Then the deformations become acceptable. (the last two pictures)
    What am I doing wrong???
    It's impossible and illogical to have such deformations just on the first and last frame???
    Any help would be highly appreciated!
    Regards!
    2010-04
    109
    Default Re: Purlin releases and deformations
    I cant see any difference between pictures 2 and 3.
    2009-10
    32
    OK! I'll try to attach some zoom in screen shots!
    The first screen shot is the model with excessive deformations, around 350mm, which is really odd! There are "xxxfff" releases (simply supported purlin and bracing)!
    The second screen shot is showing "xxxfff" bracing release and "xxxxx" purlin release! (The deformations in this model are expected to be around 30-35mm)
  1. 2012: Purlin as well
    By chrisr in forum Revit Architecture - General
    Last Post: 2012-01-06, 04:57 PM
  2. Shear deformations of thick shell elements
    By rigid_joint in forum Robot Structural Analysis
    Last Post: 2010-10-29, 09:52 AM
  3. C-purlin
    By johk in forum Revit Structure - Families
    Last Post: 2008-02-15, 10:06 AM
  4. need purlin help!!!
    By Jheadley13 in forum Revit Structure - General
    Last Post: 2007-10-09, 08:06 PM
