Results 1 to 7 of 7
Thread: Produced by and Autodesk Educational Product
    I could stop if I wanted to bskripac's Avatar
    2002-04
    Columbus, Ohio
    212
    Default Produced by and Autodesk Educational Product
    When I plot a drawing the message "Produced by and Autodesk Educational Product" prints out on all four sides of the plot. Short of searching for the block that was produced this message is there a quick way to fix this problem? Oh yeah I am using AutoCAD 2005.
    2000-01
    Seattle WA USA
    5,859
    Default Re: Produced by and Autodesk Educational Product
    Search Autodesk's TS documents for details. You will need to contact your VAR for a solution. Someone has used an educational version of AutoCAD to produce drawings/blocks for commercial use, which is bad.
    13,656
    Hi
    Have you tried the Forum search facility -
    Search Forums
    A quick search returned the following threads (especially take note of any links within) -
    Educational stamp issues
    Educational plot stamps
    Have a good one, Mike
    2004-11
    I live in the Yorkshire dales - its asleep, which is the way I like it.
    35
    I thought the whole idea of printing these plotstamps was to stop people trying to use educational products for commercial use. It sounds like you are trying to use an educational product for commercial use. Personally, I don`t care, but Autodesk might not be too happy - you might be advised to tread carefully here.
    All AUGI, all the time thomas.stright's Avatar
    2015-12
    Texas
    564
    Quote Originally Posted by martin.young.78402
    That might not be the issue here. Sometimes people create blocks, templates ect while in class/training and do not understand the problems with using objects that they created while using an educational version....
    100 Club stilesj's Avatar
    Ohio
    128
    Hey Brian!
    If you know who provided you with the drawing, you may wish to let them know that the educational stamp was on it as it could cause some major problems for them, too, if they got it from somewhere else.
    Meanwhile, there is something I got at AU that may help you if you still have a copy of 2002 in the office. Supposedly you can use the Recover feature in 2002, recover the drawing, and that will remove the educational stamp. I haven't tried it myself, but It apparently ONLY works with 2002's recover. I have also heard someone suggest trying the DXFIN, then DXFOUT in 2005.
    Otherwise, I do understand that you may need to talk to Autodesk or your reseller to prove your license status and ask for help in removal.
    Good luck!
    2002-04
    Columbus, Ohio
    212
    Just to get back to you, the DXFOUT worked. Thanks.
  1. Replies: 0
    Last Post: 2015-08-07, 05:48 PM
  2. Remove "PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT" in the plot.
    By milad004122389 in forum AutoCAD General
    Last Post: 2009-11-17, 09:50 PM
  3. Educational Product Plot Stamp:
    By rrufer in forum ACA General
    Last Post: 2008-07-02, 04:14 PM
  4. PLOT STAMP OR EDUCATIONAL PRODUCT?
    By shabanshah007 in forum AutoCAD Customization
    Last Post: 2008-07-02, 04:12 AM
  5. Produced by an Autodesk Educational product
    By alhasanat-augi in forum AutoCAD General
    Last Post: 2007-02-06, 08:13 AM
