Thread: Is there a limit on number of views/elements you can insert from file?
    2004-06
    Memphis TN area
    7,048
    Default Is there a limit on number of views/elements you can insert from file?
    I'm trying to bring in some drafting views from another project. If I go through and pick all the details I need and bring them all in at once, it simply says it can't import the view and/or the objects. If I go back and select maybe 5 or 6 views at a time, it brings them in just fine.
    So is there some sort of practical limit to the number of views or elements that can be brought in using the Insert Views from File tool?
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    Default Re: Is there a limit on number of views/elements you can insert from file?
    I've had issues if a view was corrupted somehow....but I have transferred over 200 details before...
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
    2001-12
    Irvine, CA
    7,567
    There isn't a formal acknowledged number from Autodesk afaik. Is there a real limit? I would be inclined to think that it isn't the number of views but a problem view (as suggested in a earlier reply) in particular preventing it. For example, if there are 50 views offered, what happens if you try the first 40 instead? The first 30?...different grouping to try to pin down which "one" view is causing a problem. Assuming it makes sense, what if you just select sheets instead? Sheets will bring their associated eligible views automatically, nice feature.
  1. 2013: Multiple insert views from file(s)
    By LP Design in forum Revit Architecture - General
    Last Post: 2015-01-23, 02:39 PM
  2. Unable to copy elements error while using Insert from File command
    By mzabritski in forum Revit Architecture - General
    Last Post: 2012-02-10, 08:59 PM
  3. Drafting Views - Insert from File
    By techsupport.161645 in forum Revit Architecture - General
    Last Post: 2010-02-02, 07:56 PM
  4. Insert Views From File
    By ben.115043 in forum Revit Architecture - General
    Last Post: 2009-04-07, 07:54 PM
  5. limit number of open views
    By comhasse in forum Revit Architecture - Wish List
    Last Post: 2007-01-19, 09:59 AM
