Thread: Sheet Set New Subset
    2010-11
    15
    Question Sheet Set New Subset
    I have a sheet set with several drawings in it but per the users guide, when I right click to create a new subset the words are there but are gray and won't let me select. Any help will be appreciated.
    2008-05
    Boston
    65
    Default Re: Sheet Set New Subset
    Make sure you have a drawing open.....any drawing, it doesn't matter. If no drawing files are open, the option is grayed out.
    2010-11
    15
    Smile Re: Sheet Set New Subset
    I had several drawings opened but as it turns out a drawing from that sheet set must be opened.
    Thanks for the help. Sometimes this is like speeking another language. If you don't know it, you don't know it.
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,259
    Quote Originally Posted by rcooper.269779 View Post
    I'm going to go ahead and move this from the CAD Management forum to the AutoCAD area so the information can benefit more autocad users. Thank you.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
  1. Field value by current Sheet Subset
    By Yancka in forum AutoCAD Fields
    Last Post: 2009-12-26, 08:53 PM
  2. Subset Sheet Table
    By cadman_meg in forum AutoCAD Sheet Set Manager
    Last Post: 2007-12-06, 03:14 PM
