Results 1 to 7 of 7
Thread: Masking region not covering the grids
    2003-01
    59
    Default Masking region not covering the grids
    Hi every one,
    I have a Revit model linked to my interior file and need to cover a part of the grid, but I used a masking region and it does not cover the grids. Any idea how to fix this problem?
    Thanks in advance
    2002-09
    Madison, WI
    5,688
    Default Re: Masking region not covering the grids
    Duplicate view with detailing and adjust the 2d line representation of the grids.
    I don't believe you can mask grid lines.
    Only other thought would be to use a broken grid line (grid w/ gap) type. I'm not sure if that was one we found, created or came OOTB. It works, but not that great.
    100 Club RobG's Avatar
    2005-12
    Spokane, WA
    164
    unless i'm missing something David, even the 2D one doesn't allow it to be "broken" in the middle as desired from the image. With that said, even given the example in the image, i've never needed/wanted to hide a segment of the grid. The grid, in my opinion, is one of those things that rarely gets touched/hidden/masked, if ever.
    2002-09
    Madison, WI
    5,688
    You need the "grid gap" type if you want a grid line that still shows both ends without the middle.
    If you only need to show one end of the grid bubble, I'd adjust the 2d line.
    And you're correct you don't usually show them. However when a grid stops in a building, or there's no columns on the sheet of the plan, you should see it. Or if it's above or below that floor. ie if there's no need for the grid to be there and it doesn't relate back to anything I wouldn't want to see it.
    2005-12
    Spokane, WA
    164
    haha, dumb moment, totally forgot about that feature.
    Don't know why they don't do it like the section tool where it's a break in the middle of the line that you can just click in an instance situation instead of a type driven object.
    2010-11
    I have an MEP model with no grids. The ARCH model is linked in with grids. The same situation occurs but since you cannot manipulate the grids
    through the MEP model. Any thoughts? Other than copy/monitor and modify as indicated in previous posts.
    2001-02
    Allentown, PA
    207
    You can create a generic annotation family with only a masking region made up of invisible lines and some parameters so that you can change it's size. Note that while the annotation family will be placed in the actual view, the size of the masking region will need to mimic the size that it will appear on printed paper.
  1. 2014: Transparent Cross Hatch Region lines covering Model Elements
    By sam-archs in forum Revit - Platform
    Last Post: 2015-07-18, 12:38 AM
  2. 2013: Masking region not masking: wireframe is not on
    By graphite in forum Revit Architecture - General
    Last Post: 2012-09-14, 03:28 PM
  3. 2012: Masking Region not masking properly -- View not set to wireframe
    By Joshua Kohl in forum Revit Architecture - General
    Last Post: 2011-11-14, 12:28 AM
  4. Fill region covering up eelctrical symbologies
    By davel.254027 in forum Revit MEP - General
    Last Post: 2011-06-13, 07:44 PM
  5. 2009/E - have Masking Region mask Grids (and other annotations) - O
    By lcamara in forum Revit Structure - Wish List
    Last Post: 2010-05-25, 08:10 AM
