Thread: Chart Definition Question
    2011-02
    2
    Smile Chart Definition Question
    Hello,
    I am an Autocad newbie. I have a file called a "Chart Definition". It comes from another software. Inside it is a set of coordinates like these:
    #n         east        north    angle      width     height
      1   584292.227  6579265.577   48.356    920.000    450.000
      2   584659.581  6579678.343   54.889    920.000    450.000
      3   585030.636  6580085.329   36.671    920.000    450.000
    These are like "view port" boxes. How do I put/create this in Autocad Map?
    I'm sorry for not being too clear. I do not know what questions to ask. I will gladly reply to all clarifications asked in this thread.
    Best Regards
    TN/KY Area
    1,640
    Default Re: Chart Definition Question
    What file format is the data in? Can you save it to a standard txt, CVS or Excel format? Are you wanting the "chart" in the dwg or do you need points from the data to be created?
    2011-02
    2
    Quote Originally Posted by MURPH View Post
    The data with the "east, north, angle, width, height" is a standard txt file. I want to create a dwg file with the "boxes" / "view ports" based on the coordinates and angles found inside the txt file.
    My situation is that I will need to make a series of charts and each "box" / "view ports" is overlapping each other a few meters.
    Please see attachment for explanation. I hope the image i created is helpful.
    Thanks so much for the reply.
    TN/KY Area
    1,640
    The Plan & Production tools in Civil3D has something like that, with MAP3D you need to use a custom routine. Might want to post in the Programming forums.
  1. 2014: Chart Key Notes
    By settel in forum AutoCAD General
    Last Post: 2014-01-21, 01:51 PM
  2. 2011: Ductwork block definition/ layering question
    By EUGENIE_TRC281577 in forum AMEP General
    Last Post: 2011-09-23, 09:21 PM
  3. Line type definition duplicate definition problem.
    By AJGKennedy in forum ACA General
    Last Post: 2010-06-22, 06:55 PM
