Thread: Problem with Hosted Panels
    Active Member Saimon's Avatar
    2009-06
    Orlando
    64
    Default Problem with Hosted Panels
    Hello,
    I'm working with hosted panels on a project. I have circuited to most panels already, but I need to re-arrange the layouts of the electrical rooms, this means moving panels around.
    There are some panels in the model that will not give my the opportunity to pick a new host, therefore I can only move the along the axis to which they are hosted. If I move it way out of the wall to which the panel is hosted, in an attempt to "un-host" the panel so I can pick a new host, I loose all circuits in the panel.
    Some people seemed to have run into this problem before, but I'm wondering if anyone has found a fix. I cannot modify the family to delete the hosting element form the project and load it back in, since deleting the hosting element from a family is not an option with hosted families.
    Thanks in advance for any help provided,
    Simon
    2011-04
    3
    Default Re: Problem with Hosted Panels
    I'm having a similar problem. Did you ever find a solution?
    Thanks
    2011-04
    3
    There were assigned spares and spaces in the panel schedule. I removed the spares and spaces and then I was able to rehost the panel. Not sure if it was a fluke, but maybe it will work for someone else as well.
  1. Replies: 9
    Last Post: 2011-06-14, 10:33 PM
  2. face hosted symbols in lieu of wall hosted
    By timsea81 in forum Revit MEP - General
    Last Post: 2010-02-26, 07:50 PM
  3. Roof Hosted Family Problem
    By lammarlon in forum Revit MEP - General
    Last Post: 2009-05-18, 05:42 PM
  4. Problem with curtain wall panels
    Last Post: 2007-03-09, 05:33 PM
  5. Problem with Sloped Glazing Roof Panels
    By dvanburen in forum Revit Architecture - General
    Last Post: 2006-11-07, 01:43 AM
