Thread: Why three duct connectors in fan powered terminal units?
    2010-08
    32
    Default Why three duct connectors in fan powered terminal units?
    I don't get it. In manufacturer's content for fan powered terminal units, the manufacturers I have seen, and even the fan powered terminal content from Revit, includes an unused duct connector on the plenum inlet of the fan powered terminal units.
    Don't get me wrong, I understand fan powered terminal unit design and operation.
    The air systems I design use the cooling load design air flow as the dictating air flow for duct sizing and equipment selection, so therefore in my fan powered terminal unit families I do not plan to put an extra duct connector at the plenum inlet.
    Is there something I will mess up by doing this, or...maybe I should say by not doing that?
    Thanks.
    2009-02
    42
    Default Re: Why three duct connectors in fan powered terminal units?
    Not everyone does that.
    Check out the fan-powered ATUs from METALAIRE --
    http://www.metalaire.com/BIMLibrary.aspx
    They show an area for the plenum inlet, but there's no connector on it.
    If you're not going to be attaching duct, you really shouldn' th ave a duct connector there. These guys at least seem to know that.
    2010-08
    32
    Thank you. I needed to double check that was ok to do...or in this case not do.
  1. 2014: Duct Terminal Arrow
    By gvluisi in forum Revit MEP - General
    Last Post: 2015-05-07, 01:06 PM
  2. 2014: Air Terminal on Duct
    By slovenc0417 in forum Revit MEP - Families
    Last Post: 2014-05-27, 01:54 PM
  3. 2011: Duct Connectors - drag to connect to other connectors
    By bb1 in forum Revit MEP - General
    Last Post: 2011-09-07, 07:56 PM
  4. 2011: Terminal Box with Multiple Connectors
    By magicjsh853179 in forum Revit MEP - Families
    Last Post: 2011-07-14, 12:16 AM
  5. Good Source of Info on Terminal Units?
    By retroart143895 in forum Revit MEP - General
    Last Post: 2007-09-18, 04:17 PM
