Results 1 to 7 of 7
Thread: Changing background color via Lisp
    2001-01
    257
    Smile Changing background color via Lisp
    Hi All
    I am working on a routine to restore our office's standard setting and I am having trouble with restoring the drawing background color. I have tried the following piece of code with no luck at all. Any help is greatly appreciated. Thanks.
    Manuel
    (vl-load-com)
    ((vl-registry-write (strcat "HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\R18.1\\ACAD-9001:409\\Profiles\\"  (getvar "cprofile") "\\Drawing Window") "Background" "0"))
    2009-11
    5,719
    Default Re: Changing background color via Lisp
    Look into the GraphicsWinModelBackgrndColor and the GraphicsWinLayoutBackgrndColor properties, of the PreferencesDisplay object.
    Computer Specs:
    2005-09
    111
    See: http://forums.autodesk.com/t5/Visual...or/m-p/1605657
    (defun c:wb () ;;white background
    (setq acadobject (vlax-get-acad-object))
    (setq acadpref (vlax-get-property acadobject 'preferences))
    (setq acaddisp (vlax-get-property acadpref 'display))
    (vlax-put-property acaddisp 'GraphicsWinmodelBackgrndColor 16777215)
    (vlax-put-property acaddisp 'ModelCrosshairColor 0)
    (defun c:bb () ;; black background
    (vlax-put-property acaddisp 'GraphicsWinmodelBackgrndColor 0)
    (vlax-put-property acaddisp 'ModelCrosshairColor 16777215)
    Regards HofCAD CSI.
    2001-01
    257
    Hofcad
    Can you tell me the names of the variables for paperspace background and crosshair color? Thanks.
    Manuel
    Earth
    9,805
    Here is a method to toggle the color between black and white: http://cadpanacea.com/node/50
    R.K. McSwain | CAD Panacea |
    Earth
    9,805
    Quote Originally Posted by cadconcepts View Post
    Hofcad
    Manuel
    That should be answered in this post.
    2001-01
    257
    That worked. Thank you all for your help.
    Manuel
  1. 2014: Changing the Color of the Display Paper Background!?
    By WJM_Jr in forum AutoCAD General
    Last Post: 2013-10-07, 06:47 PM
  2. Change command line background color lisp
    By Dave Lewis in forum AutoLISP
    Last Post: 2012-08-07, 07:17 PM
  3. Changing Background Color
    By sinanbakir in forum Revit Structure - General
    Last Post: 2010-11-12, 04:42 PM
  4. Lisp for changing layer color in XREF's
    By cadd4la in forum AutoLISP
    Last Post: 2005-09-28, 01:16 PM
