Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Data Shortcutting Profiles
  1. #11
    2004-03
    12
    Default Re: Data Shortcutting Profiles
    I am very happy to hear that it is just me.
    And thanks for doing what I have been too busy to fuss with.
    Be glad to get any pointers you might have. This weekend I think I might start from scratch and see if I can get it to work correctly and what introduced the error, assuming it will duplicate.
    Also I have it packaged if you want to fuss with it. I noticed I was not the only one with this issue so some deep analysis might help others if someone can pin down the cause. Either a dropbox (to mike.monical@comcast.net) or ftp would work.
    Thanks again.
    Mike
  2. #12
    2004-03
    12
    Autodesk was able to sort out one solution to my issue.
    It appears the existing Data Reference (Dref, Shortcut) was at fault. Removing the alignment Dref and all profiles (from the Dref definitions) and then recreating from the source drawing solved the problem and the Data Reference Profiles successfully referenced without creating a duplicate alignment definition. I had not tried that as I was concerned that removing the existing Drefs would break the link and all the links would have to be remapped. That was not the case and the existing alignment which was Dref'ed successfully sinc with the new Dref seamlessly.
    It is worthy of note that since you cannot "send" the existing dref links anywhere, providing drawings to troubleshoot did not reveal the problem as the Drefs had to be recreated anyway which solved the problem. It was only by remoting in to my computer the Autodesk technician was able to see the issue and help me fix it (Thank you Tatiana). Note the underlying problem with the Data Reference was not resolved.
    So AutoDesk gets the gold star on this one.
    Mike
  3. #13
    2001-10
    Arizona
    2,337
    Mike, I tried but could not reproduce your error; due to the condition you noted above.
    Actually it IS possible to send ones data shortcuts, they will need to be pathed to the location of the originating file(s) in the new folder(s) on the recieving end to 'fix' the broken links.
    Gold star...I think perhaps Bronze would be more in order.
    See actually she only found the error because she didn't fix the broken link, or didn't know how do do so. So she resorted to using remote desktop to 'solve' the problem.
    Either way glad that I could help and that you have the issue resolved.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
  4. #14
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,384
    On a side note - Sending files with Data shortcuts. If you use eTransmit and make sure the folder structure remains "As Is" you will be able to keep the data shortcuts (there is an option for this in the Transmittal settups dialog)
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
  1. Data Shortcuts with Existing Ground Profiles
    By bseymour in forum AutoCAD Civil 3D - Profiles
    Last Post: 2012-01-19, 03:30 PM
  2. Data Extraction from Profiles
    By khalidisi in forum AutoCAD Civil 3D - Profiles
    Last Post: 2010-01-17, 06:09 AM
  3. nesting profiles into profiles Possible?
    By WYSIWYG-BIM in forum Revit Architecture - Families
    Last Post: 2009-08-18, 08:02 PM
  4. Data Reference Profiles for Elevations
    By chelffrich in forum AutoCAD Civil 3D - Profiles
    Last Post: 2008-09-19, 06:00 PM
  5. Profiles - Missing Identity Data
    By kstephens in forum Revit Architecture - General
    Last Post: 2006-11-04, 02:01 AM
