Results 1 to 10 of 17
Thread: modeling depressed slabs
    2009-08
    77
    Question modeling depressed slabs
    How are you modeling depressed slabs? For example, where you have a 6" slab, and want to show a 2" depression for tile at a bathroom, etc. (I'm not worried about modeling the slope for any drains - I usually just detail line that part).
    Modeling a 6" slab with a hole in it, and then modeling a 4" slab separately at that area is a drag because every time it needs adjusting (which is often) twice as much editing is required.
    I was thinking there was a way to create a partial void that I could embed just a little bit into the slab (model the slab full thickness and then just 'void' out the depressed area), but everything I'm seeing cuts out the entire thickness of the floor, not just the top two inches.....?
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    1 members found this post helpful.
    Default Re: modeling depressed slabs
    How your doing it is how we do it currently....have heard that some people will add a void to floor based family....but it can be tedious if you have an irregular shape...
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink or :whiskey: or :wine:"
    2002-09
    Madison, WI
    5,480
    One trick is to align and then lock the 4" slab to the opening in the 6" slab. I've gotten this to work in the past. However you may run into issues with over-constraining. Also the model may have performance issues when editing the slab.
    Using 2 slab and joining them is the only way I've heard off. It's also the easiest and least likely to cause major issues in the end.
    Of course the other option is to not model it. In the end the floor is going to be flat. In your detail you could simply mask the void. But this gets into that whole question of model sharing. I wouldn't know there was a void there if I just had your model linked. So I guess it's users choice. I've had to many MEP consultants use the excuse "Well they'll just adjust that in the field and I don't have time to redo all my piping routes so....we're just going to leave it where we have it now." Damned if you do, damned if you don't.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    100 Club lzaras's Avatar
    2001-03
    United States, next to a Lake
    130
    Ditto to your two separate slabs.
    Ditto to David's suggestion of locking the edge of the 4" slab to the hole in the 6" slab.
    Lucky for me, most of my depressions have been pretty rectangular so far so I haven't run into any "over-constraining" issues.
    Leanne
    AutoCAD 2010 Certified Professional
    Revit Architecture 2012 Certified Professional
    Revit Structure 2015 Certified Professional
    2013 Gunslingers, 2015 ITF-Live
    Charlotte, NC
    Revit2014 / Revit2015 / ACAD2014
    2009-08
    77
    That spawns another question I have about locking elements (which I've addressed in another thread).
    Thanks all for the input!
    2006-05
    836
    I use a face based void family so it cuts into the floor, but does not generate a new Structural analytical element. For edge like this they are quite easy to move since you do not modify the skecth and break any specific join conditions.
    AJS
    BIMM Consultant
    www.GHD.com
    2009-08
    77
    Is that a custom void family with depth parameters added to it? Revit's built-in face based opening tool just cuts through the whole element with no thickness or depth adjustment (or am I doing something wrong?)
    2006-05
    836
    Yes it is a custom floor based void family.
    Be aware if won't affect concrete beams or framing members but will cut through floors. Keep all parameters as instance properties.
    AJS
    BIMM Consultant
    www.GHD.com
    100 Club Steve Mintz's Avatar
    2006-03
    San Diego, CA
    169
    I don't like the idea of modeling two different floors. It has a number of downstream effects that may adversely affect model updating and structural analysis.
    In a few of my AU classes, I walk through how to create a slab depression family. It also hatches itself for construction documents.
    I think the most complete tutorial is found in this class:
    http://au.autodesk.com/?nd=e_class&session_id=5234
    2009-08
    77
    Thanks Steve!! In looking at the lab info, I think I saw the presentation version in AU Virtual at one point. I was only on my first or second Revit project at the time, so I had bigger fish to fry than slab depressions, but it was a great presentation.
    Your solution works great for most of my situations. Before I even try, is it possible to make a similar void family that would be sketch based, so you could outline complex shapes? I see that you can hook multiple rectangles together, but I have a couple depressions with angles, 17 corners, etc.
  1. Replies: 0
    Last Post: 2014-12-01, 03:38 AM
  2. 2012: FOUNDATION SLABS, SLAB EDGES AND FLOOR SLABS: VISIBILITY ISSUES
    By andrewo789983 in forum Revit Architecture - General
    Last Post: 2012-09-12, 04:48 PM
  3. Geometric Modeling? Parametric Modeling? BIM?
    By burcugokcen in forum Software
    Last Post: 2007-10-25, 09:11 PM
  4. Modeling Balconies in Floor Slabs
    By JONB.102117 in forum Revit Architecture - General
    Last Post: 2007-06-15, 07:24 PM
  5. Slabs, Roof Slabs and Structural Components
    By BCrouse in forum ACA Wish List
    Last Post: 2005-10-14, 09:09 PM
Tags for this Thread
