Results 1 to 7 of 7
Thread: OLE vs Raster Image
    2007-06
    2
    Default OLE vs Raster Image
    I'm inserting my clients' logos into a title block following the help instructions for embedding an OLE, but it keeps inserting as a raster image. When the client plots it, there's no image since the file reference is to my computer. I'm using a trial version of 2011.
    0,0,0 The Origin
    8,024
    Default Re: OLE vs Raster Image
    IME, OLE images are a dead loss in acad.
    I always reconstruct client logos with acad objects. It's not for everyone, I guess.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    Active Member Julesagain's Avatar
    2005-06
    Atlanta
    96
    Quote Originally Posted by smcgonagle View Post
    Can you not attach the image using the IMAGEATTACH? You'd have to include the file with the drawing, but if you give it a relative path instead of a specific one, it should find it if they're in the same directory.
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Insert the image into an MS Office application (eg. MS Word), then copy (Ctrl+C) from there and paste it (Ctrl+V) inside AutoCAD. This will force the image to be embedded as an OLE object instead of raster image.
    har!s
    CADing && Coding
    AuotCAD 2010 on Windows XP Professional (SP3)
    Member JMonrex Gadgude's Avatar
    2004-12
    Italy & Philippines
    43
    hi
    i use always ole object in my drawing instead of raster image. first i open the raster image in media editing programs, like my case i use PhotoImpact , inside photoimpact select object, then copy. open autocad then paste or ctrl+v.
    other method:
    right click on the image (picture) > open with - Paint, then tools >modified >select all
    then back to autocad command ctrl + v.
    the advantages of using media editing progs is you can modify the resolution or resize the picture.
    i use a proportion of 300x200 pixel for plot scale 10=1.
    have a happy autocaddinggg!!!
    2007-06
    2
    Thanks, Zoomharris. It helps to detatch the link first, but cutting and pasting from a document worked.
    100 Club Lemons's Avatar
    2001-06
    Beautiful Charleston, South Carolina
    149
    Quote Originally Posted by jaberwok View Post
    I'm with you 100% on this one. It's so much easier all around to have the logo as an acad block. If the logo changes (we get ones that do) it's just a matter of redefining the block.
    Drop me off in Asheville.
  1. Raster Image Bog Down
    By joseph_turc in forum Revit MEP - General
    Last Post: 2010-09-27, 04:16 PM
  2. No Raster Image in PDF
    By wayne.peterson in forum Raster Design - General
    Last Post: 2010-08-23, 11:13 AM
  3. Printing a Raster image
    By madyb in forum Revit Structure - General
    Last Post: 2010-07-30, 08:19 PM
  4. Resolution of Raster Image
    By epearce in forum Revit Architecture - General
    Last Post: 2010-02-16, 10:07 PM
  5. Help with Raster Image!!!
    By kim.74445 in forum Revit Architecture - General
    Last Post: 2004-11-02, 11:43 PM
