Results 1 to 7 of 7
Thread: Light fixture placement
    Member MatthewStuver's Avatar
    2011-02
    Columbus, Ohio
    7
    Default Light fixture placement
    I have an issue and I am not sure how to fix it. I am on the first floor RCP, placing a can light fixture on the face of the ceiling grid. This is a linked in arch file, and I am using Revit MEP 2011. When I select "Place on Face", I can see the can as my pointer on the ceiling grid, but when I move it to the left all of a sudden it disappears. Please see attached zip file with a little video.
    Any thoughts?
    Matthew Stuver
    Active Member troy.crandell635379's Avatar
    2007-06
    Phoenix, AZ
    72
    Default Re: Light fixture placement
    I'm having the same problem. Have you found a solution?
    Troy Crandell
    BIM Implementation Specialist
    AUGI Addict matt__w's Avatar
    2002-06
    North Central CT
    1,108
    Is there really a ceiling grid there or was it fudged with lines? When you look at it in 3D, is the can light REALLY attached to the ceiling?
    Matt
    2008-08
    Atlanta, Ga.
    95
    Is the view range set properly and can you see it in the lighting plan( NOT the ceiling plan). Also do a 3d view of the plan to see where it is placed.
    2007-06
    Phoenix, AZ
    72
    There is definately a ceiling in the architecture model. I can see it in section and 3D, and the view range can't be an issue since the light will host to the same ceiling in a different spot. And no, the ceiling isn't sloping.
    Troy Crandell
    2011-01
    59
    Does the arch have a fixture placed in the area? If so arch lights create a void in the ceiling so there is no ceiling for you to host to.
    2002-06
    North Central CT
    1,108
    Open the archie's model and disect that area of the building. At 0:07 of the video, you're crossing the edge of something. Try a tab-select in that area to see what items are there. SOMETHING is there.
  1. 2014: Light fixture does not produce light in rendering
    By ctc in forum Revit Architecture - Families
    Last Post: 2014-04-11, 07:56 PM
  2. Replies: 0
    Last Post: 2013-04-04, 05:40 PM
  3. Revit light fixture light source geometry won't go away
    By david_spehar in forum NavisWorks - General
    Last Post: 2012-02-21, 09:05 PM
  4. Generic Light Fixture Familys vs Project Specific Fixture Data
    By AnnieJ115 in forum Revit MEP - General
    Last Post: 2011-09-28, 05:37 PM
  5. IES Light Data with Light fixture Family
    By yuthana in forum Revit Architecture - Families
    Last Post: 2007-02-23, 12:44 PM
