I have done this process many times and familar with the 2 mile radius
but I keep getting this error message while loading this dwg (attached below).
... has extents greater than 1e9 in AutoCAD units. Data exceeding that range will be truncated...
I have tried everything I can think of to check for invisible elements and even did a cut and paste
into a new dwg file but no success.It comes in truncated and unuseable.
I have also done a purge and audit.
I did move the geometry to the origin 0,0 and I get the message but the dwg does come in.
This not ideal as there are several civil dwg files that need to be used for this project and
with regular updates. Plus we need the Eastings and Northings in Revit.
If anyone can help it will be much appreciated.
I have included the dwg file.
The AutoCAD file is in millimetres and the Revit file is also in millimetres.
The AutoCAD being used is 2009 and Revit Architecture is 2011
Thanks in advance
Richard
