I'm not able to send the xref base plan in model space to the back or under the work, is there a simple resolition?
Sometimes it isn't enough to send an item to the back, particularly when it comes to x-refs. You may have to bring the other items to the front as well. (Don't know why)
You can also add some transparency to your x-ref in order to see what's behind it. I've had items hide from view behind hatch in the x-ref. I love the new transparency tool. You'll find it on the HOME tab.
Sometimes I have to type REGEN to "refresh" the drawing so the draw order visually shows the adjustment made.
