Thread: Fixing a block that uses same name attributes without losing existing block data during BATTMAN sync
    2008-05
    Boston
    65
    Default Fixing a block that uses same name attributes without losing existing block data during BATTMAN sync
    Here's a solution that may help someone:
    I was recently given a cad plan that had room tags in it comprised of three attributes:
    "room_name"
    "room_name"
    "room_no"
    Someone apparently had copied the room name attribute without renaming it in order to create a block with two lines for the room name.
    If I edited the block attribute names to "room_name1" and "room_name2", and then used BATTMAN to sync the revised block definition, every instance of the block in the drawing lost the values for those attributes and left only the room number portion of the block.
    How I fixed it:
    1. Selected all of the room tag blocks and used ATTOUT to create a txt file of the block attritbute values.
    2. Edited the block definition to change attribute names to "room_name1" and "room_name2".
    3. Used BATTMAN to update all of the inserted blocks to have the renamed attributes (which made the room name data disappear from each block instance).
    4. Opened the txt file and renamed the two "room_name" titles in it to "room_name1" and "room_name2" to match my revised block.
    5. Used ATTIN and this txt file to import the room name values to all of the existing blocks.
    2012-04
    Default Re: Fixing a block that uses same name attributes without losing existing block data during BATTMAN sync
    Just helped me a /whole/ bunch.
    Except it was four "ROOMNAME"s, 1100 blocks, and between this and my lisp routine that replaced them all once I could isolate the text on each line, it worked. I probably wouldn't have found this solution on my own.
    Thanks!!!
    //Aaron.
    2007-07
    Jo'burg SA
    4,348
  1. importing data into block attributes
    By tparvind in forum AutoCAD Customization
    Last Post: 2011-06-27, 09:46 PM
  2. Extract data from Dynamic block with attributes
    By mahesh.darekar in forum AutoLISP
    Last Post: 2009-01-24, 03:56 AM
  3. Add attributes to an existing block
    By dvannoy in forum AutoCAD General
    Last Post: 2007-10-17, 02:45 PM
  4. Updating Existing Block Attributes
    By SteveBig in forum Dynamic Blocks - Technical
    Last Post: 2005-11-04, 12:58 PM
