Thread: Model soil stiffness for slab on ground design
    2011-02
    21
    Default Model soil stiffness for slab on ground design
    Not sure if I can model soil stiffness on an area using Robot.
    I know I can click on the "support" icon then click on "New" then "Support Definition" appear.
    So I click on "Elastic" menu ? then click on 'Elastic Coefficient" Button to define the building soil, then choose "Raft foundation" with dimension 1mx1m.
    Then choose the soil layer, I have Kz (kN/m3) for soil stiffness. Is it this value apply for the node or area I click on the model ?
    I try this and it seem applty on the edges and nodes not on the whole slab area
    Thanks.
    2010-10
    41
    Default Re: Model soil stiffness for slab on ground design
    click on FE thickness icon , New ,Parameters of foundation elasticity and then you can set springs on all 3 directions
    2011-02
    10
    Yes, I think that is better if you define soil elasticity directly in the surface FE thickness parameters. This way you will be able to display soil stresses. If you do it through support parameters i think that this is not possible.
  1. 2013: Best practice for bring Millwork from the Arch. model into my kitchen design model?
    By dmitchell404334 in forum Revit Architecture - General
    Last Post: 2013-11-19, 07:19 PM
  2. 2013 Design of RC member considering slab T and L beam
    By chikaokekeokeke366099 in forum Robot Structural Analysis
    Last Post: 2013-03-23, 08:31 PM
  3. Error of membrane stiffness matrix D?
    By jb.quocan841038 in forum Robot Structural Analysis
    Last Post: 2012-12-14, 08:57 AM
  4. Above Ground Pipe Design
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-10-06, 09:41 PM
