We have noticed that the lighting fixtures in our model are transparent (the roof structure is visible through the light.). Upon investigation, I have not found any visibility settings, either in the family nor in the view, that would cause this. Within the families, the 3d solid extrusion is set to be visible in all 'View Specific Display' and 'Detail Levels', and the Visible parameter is checked. Within the view, the category is turned on and not transparent, it's hidden line, there are no filters, and nothing is "hidden".
The view is defined to be in the electrical discipline. Interestingly, if I switch that view to architectural or coordination, the lighting category becomes opaque. (see attached reference) It appears that maybe the lighting fixture category is transparent by default in an electrical discipline? Or am I missing some other setting somewhere? Ideas?
Has anyone else experienced/noticed this? If so, are you just creating architectural views for your electrical sheets?
Any thoughts would be appreciated. The view is a ceiling plan view, and we are using Revit MEP 2011 with web update #2.
