Thread: metric drawing setup but blocks in feet
    2008-02
    12
    Default metric drawing setup but blocks in feet
    I set up my drawing as a metric 1:500.
    I create an alignment and then add the station labels.
    When I check why the labels are so small the properties show the units in feet.
    I don't know if this is a "cad issue" or not.
    I have only started using land companion 2009 so I'm not sure what issues there are
    Civil3d Land Companion 2009
    100 Club amaser's Avatar
    2006-05
    Joliet, IL
    105
    Default Re: metric drawing setup but blocks in feet
    Look in the options section under User Preferences. There's a section called insertion scale.
    Both should probably be set to Unitless. In addition, it's possible that the block itself is designed as feet.
    There is also a System Variable called INSUNITS, INSUNITSDEFSOURCE, INSUNITSDEFTARGET that could be set either to unitless or to Meters.
    2008-02
    12
    After some research all over the web I found the same answer as you posted (couple different web sites and some time). I knew that the block was in metres.
    I would caution people that you check the settings for INSUNITS INSUNITSDEFSOURCE, INSUNITSDEFTARGET before you start using companion.
  1. Cannot change drawing scale - in drawing setup
    By cdoucet in forum ACA General
    Last Post: 2009-07-20, 08:11 PM
  2. Metric drawing
    By lori.england in forum AutoCAD General
    Last Post: 2008-07-16, 05:08 PM
  3. Drawing in decimal feet
    By r.vetrano in forum AutoCAD General
    Last Post: 2007-05-31, 05:57 PM
  4. metric and feet contours
    By jenniferchavez in forum AutoCAD Map 3D - General
    Last Post: 2005-06-14, 03:45 AM
