Has anyone run into an issue with the Revit UI not displaying across Windows Remote Desktop? In particular, the Application Window, Ribbon, Quick Access Toolbar, and Communication Center are not visible thru the remote session. They are there, you can click and launch commands but they are not visible. The project browser, options bar, properties pallettte and viewing area all display correctly.
Also worth noting, all other application work fine with the exceptino of Autodesk. Autocad and Design Review also have the same issue. The same items mentioned above do not display across RD. This includes Revit 2011, Revit 2010, Autocad 2011, Design Review...etc.
I can only get Revit 2010 with the 2009 UI Switch to work correctly across RD! Kinda funny..it works.
This is going from a Windows 7 Professional x64 machine to another Windows 7 Professional x64 machine. Both machines are running the latest version of Revit, Windows 7 SP1 installed. Both have the same and updated video card drivers. Dell t3500's...
Also used LogMeIn with the same results...no ribbon...
Any suggestions are much appreciated!
