Thread: "namespace for closing document is not found"
    2008-05
    Boston
    65
    Default "namespace for closing document is not found"
    Hello,
    Acad 2011 will not open a dwg file created by Illustrator CS5. It only flashes a quick message "namespace for closing document is not found".
    Acad 2010 will open the same dwg file without problem.
    Does anyone know how to get 2011 to open such a drawing file? Eventually I don't think I'll have the option to open these files in 2010.
    Thank you.
    Houston
    7,520
    Default Re: "namespace for closing document is not found"
    Each subsequent version of AutoCAD is more stringent than the previous in validating data during open/import operations. It sounds like 2011 is finding errors in the DWG file that 2010 isn't catching.
    Have you tried the ._RECOVER command in 2011?
    Can you export from CS5 to another format (DXF?)
    Cairo - no, not Illinois
    2,729
    you might want to try loading Draftsight (free cad app) and see if that gets better results with a dwg originating in Illustrator
    Officially Awesome
    2008-05
    Boston
    65
    Recover didn't work.
    However, Illustrator can export a DXF and ACAD 2011 opened that format without problem.
    It's been eons since I've had to use dxfs, so I'd completely forgotten about them.
    Thank you!
  1. XREF "Saved Path" to "Found at" location
    By cadmancando in forum AutoLISP
    Last Post: 2012-01-18, 02:54 PM
  2. "Drawing is busy", Closing all open drawings.
    By bmcdaniel in forum Dot Net API
    Last Post: 2007-10-16, 06:42 PM
  3. Tool Palette "Block definition not found" Error
    By .chad in forum ACA General
    Last Post: 2007-03-16, 06:18 PM
  4. "central location cannot be found" error message
    By Revitator in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-05-02, 04:37 PM
  5. "cannot open view closing window"
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2005-06-20, 02:37 AM
