I want to have my footing offset to sit below the slab edges. Cant seem to figure this out.
How deep are your slab edges? Have the Base Offset for your wall be that distance.
Leanne
AutoCAD 2010 Certified Professional
Revit Architecture 2012 Certified Professional
Charlotte, NC
RST2010 / RST2011 / RST2012 / RST2013 / ADT2006 / ACA2010 / ACA2013
is this footing modelled as associated to your wall? Ie its a wall footing? It looks as though it is
If so, it is associated to the BASE of your wall. I suggest you do an isolated footing, either that or you need to set your wall to <-slab thickness> below slab which will set your footing under your slab, I would suggest you include the depth of those tapers if you do it that way.
