I have an autocad 2008 file that has a small problem I can't understand how to fix.
The Layer tool is NOT showing the layer in alphabetical order. In the Layer properties manager the layer list in Alphabetical as always. Here is a little history about the file:
Civil site plan with an architectural building xref in. The architectural drawing is a drawing which was created with AutoArch 2010 and save back to Autocad 2008.
The user found that any new layer created shows up at the end of the list when he list out using the Layer Tool bar.
Any ideas on how I can fix this small problem.
Thanks
I just open a copy of the file to have a better look and found that this has 20 Orphaned...
Once I detach these Orphaned the Layer Tool right...
