Results 1 to 6 of 6
Thread: multiple conditional formating
    2015-09
    481
    Default multiple conditional formating
    I am trying to get the parameters to turn off the other two when that particular type is being used. But the way i am wirting it now (as shown below), i cant write the expression this way because it says its a circular reference for the others
    How can i write this so it works?
    Thanks
    2015-09
    481
    Default Re: multiple conditional formating
    Well i have it working use a separate parameter with integer to control the visibility
    2006-04
    Calgary, Alberta
    143
    Try this: and(not(Annotation Centre), not(Annotation Right))
    2015-09
    481
    I get the circular referencing for that as well.
    2006-04
    Calgary, Alberta
    143
    Looks like you're using instance parameters, are you sure you want them to be instance parameters? I would prefer type parameters unless absolutely necessary. I like being able to make a few types and change them from the Type Selector.
    You'll have to remove the other formulas first, then add in the formula above: and(not(Annotation Center), not(Annotation Right))
    Watch out for my Canadian spelling of 'Centre'; I've changed it to US spelling. Crazy Canucks.
    2015-09
    481
    [quotes]Watch out for my Canadian spelling of 'Centre'; I've changed it to US spelling. Crazy Canucks. [\quotes] LOL
    I'm almost positive i had them as type parameters, only because i have the different types setup for them. Ill check again....that crazy spelling of yours may have distracted me ;:
  1. Multiple Conditional Formats for Schedules
    Last Post: 2015-06-03, 06:21 AM
  2. Conditional formating in schedules
    Last Post: 2012-07-24, 03:34 AM
  3. remove formating of dim
    By clovis in forum AutoLISP
    Last Post: 2011-05-04, 02:47 PM
  4. Multiple Conditional Statement Formulas
    By cdsuggs in forum Revit MEP - General
    Last Post: 2010-07-01, 03:59 PM
  5. Multiple conditional yes/no "options"
    By ford347 in forum Revit Architecture - Families
    Last Post: 2008-02-11, 06:41 AM
