Thread: Revit Schedules
    2009-02
    Florida
    35
    Default Revit Schedules
    I am trying to create a Life Safety table with information like gross building area and occupancy areas.
    My first inclination was to create the formatting (like lines and such) in a sheet exactly like we do in AutoCAD. Then create seperate schedules for gross building area and department area. Then insert these schedules in the proper place in the drawn table.
    So I have a section that calls for 1st floor area and 2nd floor area. No problem, I created a schedule based on gross floor area with the level as a category. I inserted it and it looks great.
    Next, I organized all the rooms into the proper occupancy (like business, assembly, storage etc.) with the "department" parameter. I can do a room schedule categorized by department and then get totals, but how would I only 'extract' the department totals to my sheet? I know that the calculated totals only exist in the schedule. So is there a work around?
    How do others create a parametric table like the one I am describing? Perhaps I am dreaming and you have to enter this info in manually
    Any help would be greatly appreciated.
    Kindest Regards,
    d
    100 Club cganiere's Avatar
    2015-09
    Costa Mesa, California
    117
    Default Re: Revit Schedules
    Are you looking for something like this?
    2005-07
    Somewhere in the BIM world
    3,792
    If you are looking for "sub-total" for each department, in the Schedule properties, under Sorting/Grouping sort By Department then check Footer. In the list, pick totals.
  1. Revit Schedules
    By 3dDavinci in forum Revit Architecture - General
    Last Post: 2011-03-08, 04:14 PM
  2. Revit MEP Schedules
    By argylem in forum Revit - Platform
    Last Post: 2010-04-12, 02:21 PM
  3. Revit 2009 and Key Schedules....?
    By twiceroadsfool in forum Revit Architecture - General
    Last Post: 2008-06-27, 05:29 PM
  4. Revit Schedules
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2006-03-24, 10:17 PM
  5. Revit and project schedules
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2003-09-08, 08:56 AM
