see attached jpg, the arc radius will change according to window width / height, but still have to figure out the way to make parametric grills (symbolic lines for now, grill number will change according to window width), parametric array is the obvious choice but how to "cut off" unneeded portion, i did tried masking region in GA or DI w/ or w/o nesting, maybe the only way is doing separated for each type using visibility parameters!?
