Thread: Section vs Elevation - Hidden lines...
    I could stop if I wanted to scowsert's Avatar
    2006-08
    Olympia, WA
    411
    Default Section vs Elevation - Hidden lines...
    Elevations won't show walls hiding behind other walls but Sections will. Am I right? Other then the linework tool is there any other way to make elevations show with hidden lines?
    2003-08
    Vancouver, BC Canada
    3,394
    Default Re: Section vs Elevation - Hidden lines...
    You can use the Show Hidden Lines tool from the View tab on the ribbon. In a pure elevation you'll need to set the view to wireframe to be able to select the wall behind the walls but once you set the view back to hidden line it should show the hidden lines.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
  1. Replies: 3
    Last Post: 2011-01-31, 03:15 AM
  2. Foundations as Hidden Lines in Elevation Views
    By bclarch in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-06-30, 03:23 AM
  3. 2D Section/Elevation Hidden Footing Dispaly
    By deedelrio in forum ACA General
    Last Post: 2005-12-27, 12:01 PM
  4. Topo lines are hidden in hidden line view b/t demo & new
    By christo4robin in forum Revit Architecture - General
    Last Post: 2005-12-12, 10:33 PM
