Does the other pc have Robot installed? Is it installed to the same folder that Robot is installed to on your pc where you referenced the tlb? IOW, is the path the same?
Interop.RobotOM.dll is the assembly generated by the compiler to connect your add-in to Robot API. You must copy it together with your add-in assembly.
Check this thread.
Find there doc and example.
