Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: drawing extraction
  1. #11
    2001-12
    54
    Smile Re: drawing extraction
    Quote Originally Posted by fixo View Post
    I wrote this lisp accordingly to explanation in the post#5,
    by this reason I left out 'Count' colum
    this lisp will write just one block and all its attribute values per every line
    From there I have 3 questions
    1. Do you need to write all the same way?
    2. Do you want to write to newly created Excel file
    or into exisiting one
    3. What the column names would be in this Excel file
    Theres is no explanation in your drawing at all
    Please explain me that well coz I won't to rewrite this lisp many times
    Mr fixo: If you would care to help, it would be appreciated.
    See new attached drawing, and Excel spreadsheet:
    Block having two attributes as shown (ITEM & QUANTITY)
    Block name can be placed into lisp and not user entered
    Block name does not have to be shown in resulting Excel spreadsheet
    One column for attribute1 (label it ITEM)
    One column for attribute 2 (label it QUANTITY)
    However, QUANTITIES for identical ITEM tags should be summed as shown in example Excel spreadsheet
    First row of Excel data for each drawing should contain drawing name
    The Excel spreadsheet should be able to be appended for similar drawings,
    but the resulting data for subsequent drawings as appended are not summed
    into any previous drawing data.
  2. #12
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,213
    Default Re: drawing extraction
    Here you go
    This program will work just for current drawing
    Excel file would be saved automatically in the same folder
    Working good for me with limited testing
    ;; helper functions
    (defun create_datafile ( / aexc awb cell cll cls colm headers row sht shts wbks)
    ;;; based on program written by  ALEJANDRO LEGUIZAMON -  http://arquingen.tripod.com.co
    ;;; edited by FATTY T.O.H. aka fixo - (vl-list->string (list 102 97 116 116 121 104 97 108 108 101 120 64 103 109 97 105 108 46 99 111 109))
      (or (vl-load-com))
      (setq	aexc	   (vlax-get-or-create-object "Excel.Application")
    	wbks  (vlax-get-property aexc 'Workbooks)
    	awb	   (vlax-invoke-method wbks 'Add)
    	shts (vlax-get-property awb 'Sheets)
    	sht	   (vlax-get-property shts 'Item 1)
    	cls	   (vlax-get-property sht 'Cells)
      (vla-put-visible aexc :vlax-false)
      (setq row 1
    	colm 1)
    (setq cell (variant-value (vlax-get-property cls 'item row colm)))
      (vlax-put-property  cell 'value2 (vlax-make-variant (getvar "dwgname") 8))
      (setq headers (list "UNIT" "QUANTITY")
      row  (1+ row)
      colm 1
      (foreach header headers
        (vlax-put-property  cell 'value2 (vlax-make-variant header 8))
        (setq colm (1+ colm))
      (vlax-invoke-method
        awb
        'SaveAs
        (strcat (getvar "dwgprefix")
    	    (vl-string-right-trim ".dwg" (getvar "dwgname")) ".xls"
        -4143
        nil
        nil
        :vlax-false
        :vlax-false
        2
      (vlax-put-property
        awb 'Saved :vlax-true)
      (vlax-invoke-method
        awb 'Close )
      (vlax-invoke-method
        aexc 'Quit)
      (mapcar (function (lambda(item)
    		    (vl-catch-all-apply (function (lambda()
    			(progn
    			(vlax-release-object item)
    			(setq item nil)))))))
    	    (list  cls sht shts awb wbks aexc)
      (gc)
      (gc)
      (gc)
      (vl-cmdf "_delay" 500)
      (princ)
    );_eof create_datafile
    (defun group-by-filter  (lst )
      (if (caar lst)
        (cons (vl-remove-if-not
    	    (function (lambda (x)
    			(and(eq (cdar x) (cdaar lst))
    			(eq(caadr x)(car (cadr (car lst))))
    					   lst)
    	  (group-by-filter
    	    (vl-remove-if
    	      lst)
    (defun group-by-qty  (lst / item out_data qty record x)
      (while (setq item (car lst))
        (setq record (car item))
        (setq qty (apply '+
    		     (mapcar 'atof
    			     (mapcar 'cdr (mapcar '(lambda (x) (cadr x)) item)))))
        (setq record (subst	(cons (caadr record) (rtos qty 2 0))
    			(cadr record)
    			record))
        (setq out_data (cons record out_data))
        (setq lst (cdr lst)))
      (reverse out_data)
    (defun extract_blockset	 (block_obj / att_list att_pairs )
         (reverse
    	   (if (and
    		 (vlax-property-available-p block_obj 'hasattributes)
    		 (setq att_list (vlax-invoke block_obj 'getattributes)))
    		 (foreach att_obj  att_list
    		   (setq att_pairs (cons (cons (strcase (vla-get-tagstring att_obj))
    					       (vla-get-textstring att_obj))
    					 att_pairs)))
    (vl-load-com)
    (defun C:QTY(/ aexc awb blkname cell cll colm csht exc_data fcol fdata
    	     fname ftype itm lastcell lastrow nwb pfset row sht)
    (setq pfset(vla-get-pickfirstselectionset (vla-get-activedocument (vlax-get-acad-object))))
    (vla-clear pfset)
    (setq blkname "KEY-ITEM")
    (if (not (tblsearch "block" blkname))(progn
      (alert "Block does not exsit.\nProgram exiting.")
      (exit)(princ)))
      (setq ftype (list 0 2 410)
    	fdata (list "insert" (strcat "`*U*," blkname) (getvar 'ctab)))
      (setq ftype (vlax-safearray-fill
    		(vlax-make-safearray vlax-vbinteger
    		  (cons 0 (1-(length ftype)))) ftype)
    	fdata (vlax-safearray-fill
    		(vlax-make-safearray vlax-vbvariant
    		  (cons 0 (1-(length fdata)))) fdata)
    ;;;select all named blocks in model
    (vla-select pfset acselectionsetall nil nil ftype fdata)
    (if (zerop(vla-get-count pfset))
     (progn
      (alert "Nothing selected.\nProgram exiting.")
      (exit)(princ))
    (vlax-for block_obj pfset
    (setq exc_data (cons  (extract_blockset block_obj) exc_data))
    (setq exc_data (vl-sort exc_data '(lambda(a b)(< (cdar a))(cdar b))))
    (setq exc_data (group-by-filter exc_data))
    (setq exc_data  (group-by-qty exc_data))
        ;;		Eof acad part		;;
        ;;	***	Excel part	***	;;
        ;; reserve an Excel file copy before you ran programm:
        (setq fname (strcat (getvar "dwgprefix")(vl-filename-base (getvar "dwgname"))  ".xls"))
        (if (not (findfile fname))
          (create_datafile fname))
        ;; define Excel objects
    	  awb  (vlax-get-property aexc 'Workbooks)
    	  nwb  (vlax-invoke-method awb 'Open fname)
    	  sht  (vlax-get-property nwb 'Sheets)
    	  csht (vlax-get-property sht 'Item 1)
    	  cll  (vlax-get-property csht 'Cells)
        (vla-put-visible aexc :vlax-true)
        (vlax-put-property aexc 'DisplayAlerts :vlax-false)
    ;;;      ;; Find the last cell :
    ;;;      ;; Invoke SpecialCells method:
    ;;;      (setq lastCell (vlax-invoke-method cll
    ;;;		       'SpecialCells
    ;;;		       (vlax-make-variant 11 3))
    ;;;      (vlax-invoke-method lastCell 'Activate)
    ;;;      (setq lastRow (vlax-get-property
    ;;;		       lastCell 'Row))
    ;;;;;;      (setq lastColumn (vlax-get-property lastCell "Column"));->> if you need it
    ;;;        (setq row (1+ lastRow));-->get the next row after
    (setq row 3)
      (foreach line exc_data
      (setq colm 1)
      (foreach single line
      (setq cell (variant-value (vlax-get-property cll 'item row colm)))
        (vlax-put-property  cell 'value2 (vlax-make-variant (cdr single) 8))
     (setq row  (1+ row))
       (setq fcol (vlax-get-property csht 'Range "A:A"))
       (vlax-put-property fcol 'NumberFormat "@")
       (setq fcol (vlax-get-property csht 'Range "B:B"))
       (vlax-put-property fcol 'NumberFormat "#0")
       (vlax-invoke (vlax-get-property csht 'Columns) 'AutoFit)
      (vlax-invoke-method
        nwb
        'SaveAs
        -4143
        nil
        nil
        :vlax-false
        :vlax-false
        2
      (vlax-put-property
        nwb 'Saved :vlax-true)
      (vlax-invoke-method
        nwb 'Close )
      (vlax-invoke-method
        aexc 'Quit)
    			(progn
    	    (list  cll fcol csht sht nwb awb aexc)
      (gc)
      (gc)
      (gc)
      (princ)
    (prompt "\n\t\t***\tStart command with QTY...\t***")
    (prin1)
    ~'J'~
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
  3. #13
    2001-12
    54
    Here you go
    ;; helper functions
      (or (vl-load-com))
      (setq row 1
     colm 1)
      row  (1+ row)
      colm 1
      (vlax-invoke-method
        awb
        'SaveAs
        -4143
        nil
        nil
        :vlax-false
        :vlax-false
        2
      (vlax-put-property
      (vlax-invoke-method
        awb 'Close )
      (vlax-invoke-method
        aexc 'Quit)
       (progn
      (gc)
      (gc)
      (gc)
      (princ)
    ;;; debug (create_datafile)
      (if (caar lst)
            lst)
       (group-by-filter
         (vl-remove-if
           lst)
        (setq qty (apply '+
           (mapcar 'atof
       (cadr record)
       record))
      (reverse out_data)
         (reverse
        (if (and
          att_pairs)))
    ;;;(extract_blockset (setq obj (vlax-ename->vla-object (car (entsel)))))
     ;; (setq exc_data nil)***********************
    ;;temp((caar (
    ;;       (cdaar exc_data)   (cdar (car exc_data))
    ;;         (car (cadr (car exc_data)))  (caadr (car exc_data)))
    ;;;(group-by-filter exc_data)****************
    (vl-load-com)
    (vla-clear pfset)
      (exit)(princ)))
     fdata (list "insert" blkname (getvar 'ctab)))
    ;;;  (vla-select pfset acselectionsetall nil nil ftype fdata)
    (vla-selectonscreen pfset ;|acselectionsetall nil nil|; ftype fdata)
     (progn
      (exit)(princ))
        ;;  Eof acad part  ;;
    ;;;         'SpecialCells
    ;;;         lastCell 'Row))
    (setq row 3)
      (setq colm 1)
     (setq row  (1+ row))
      (vlax-invoke-method
        nwb
        'SaveAs
        -4143
        nil
        nil
        :vlax-false
        :vlax-false
        2
      (vlax-put-property
      (vlax-invoke-method
        nwb 'Close )
      (vlax-invoke-method
        aexc 'Quit)
       (progn
      (gc)
      (gc)
      (gc)
      (princ)
    (princ "\n\t\t***\tStart command with QTY...\t***")
    (princ)
    ~'J'~
    Dear fixo:
    Why does program ask user to select objects when the block name is already set in the program (key-item).
    If I try to select all, program responds with pop down dialog saying none found and program exiting ??
    Does this make sense to you ? thank you for trying to help, it is appreciated so far. Did the QTY lisp work on my drawing at your testing ?
    regards, Steveo
  4. #14
    2005-05
    Pietari, Venäjä
    1,213
    Wait a few minutes
    Bertrand Russell
  5. #15
    2005-05
    Pietari, Venäjä
    1,213
    Quote Originally Posted by steveo View Post
    Steveo
    Try edited code from post#12
    Bertrand Russell
  6. #16
    2001-12
    54
    Program still does not select anything and is indicated by the popdown stating such. Why does it still fail ?
    regards, Steveo
  7. #17
    2005-05
    Pietari, Venäjä
    1,213
    regards, Steveo
    Check for file [drawingname] .xls in the same folder after this program was executed.
    I've used your "T-Rake.dwg" from attachments and file "t-rake.xls" was created
    succesfully, I don't know why this code isn't working on your machine.
    ~'J'~
    Bertrand Russell
  8. #18
    2001-12
    54
    Thumbs up Re: drawing extraction
    Fixo, thanks for all your help
    kind regards,
    Steveo
  9. #19
    2005-05
    Pietari, Venäjä
    1,213
    kind regards,
    Steveo
    You're welcome
    Cheers
    ~'J'~
    Bertrand Russell
  10. #20
    2012-05
    2
    Mr. Fixo good day with my respects,
    i am quantity surveyor . i am going to calculate steel types with spaces using filter command selection ..so i need help from you (with thanking) to show the way that i must arrange the boolean functions to do this : selecting all the texts (regardless of its layers or attributes) that containing some value such as 200 and its colour is green this is first condition the second condition (AND) all texts containing 2 parameter (1. its value is T20 , 2. its other value is L=400) ..please how can i do that in the FILTER command..very thanks.
  1. Attribute Extraction 2
    By lee.johnson in forum AutoLISP
    Last Post: 2009-01-13, 03:27 PM
  2. Replies: 2
    Last Post: 2008-07-09, 12:17 AM
  3. ISO extraction
    By campbell.58097 in forum AMEP General
    Last Post: 2008-02-08, 03:18 PM
  4. B.O.M EXTRACTION
    By philw in forum AutoCAD Tables
    Last Post: 2007-12-05, 01:51 PM
