Thread: Flipping out!!
    Active Member beardking's Avatar
    2009-07
    82
    Default Flipping out!!
    Ok, go ahead, I deserve all of the punishment you can give me for making that horrible pun. That being said, I'm having an issue with a dynamic block that I have created for a spot grade tag. It works fine up to the point of trying to make the block flippable. I can get everything to flip, but when I do, then the attribute justification becomes an issue. In the standard orientation, when you fill in the attributes all of the text goes away from the spot grade circle. When flipped, the text goes in the same direction and ends up overwriting the spot grade circle. Is there any way to make this block flippable and the attribute justification to update accordingly? I have attached my block for ya'll to enjoy and ridicule.
    Thanks in advance,
    Beardking
    Using AutoCAD 2009 to about 60% of it's potential daily.
    Active Member sandrews.253556's Avatar
    2010-06
    91
    Default Re: Flipping out!!
    I think it works just fine as you created it. You just need to use the ATTSYNC command.
    2009-07
    82
    Quote Originally Posted by sandrews.253556 View Post
    Holy cow. I can't believe that I have fought with that thing for so long and never thought to use ATTSYNC on it to get the attributes in the right spot.
  1. 2012: flipping out
    By prisimage400995 in forum Dynamic Blocks - Technical
    Last Post: 2012-01-15, 06:41 AM
  2. Flipping the origin
    By Hooch in forum Dynamic Blocks - Technical
    Last Post: 2010-05-11, 10:30 AM
  3. Key tag flipping issue
    By beardking in forum Dynamic Blocks - Technical
    Last Post: 2010-04-27, 03:11 PM
  4. Flipping!
    By georgina in forum Dynamic Blocks - Technical
    Last Post: 2008-10-20, 09:29 PM
  5. Flipping a wall
    By Henry D in forum Revit Architecture - General
    Last Post: 2003-05-29, 08:11 PM
