Ok, go ahead, I deserve all of the punishment you can give me for making that horrible pun. That being said, I'm having an issue with a dynamic block that I have created for a spot grade tag. It works fine up to the point of trying to make the block flippable. I can get everything to flip, but when I do, then the attribute justification becomes an issue. In the standard orientation, when you fill in the attributes all of the text goes away from the spot grade circle. When flipped, the text goes in the same direction and ends up overwriting the spot grade circle. Is there any way to make this block flippable and the attribute justification to update accordingly? I have attached my block for ya'll to enjoy and ridicule.
Thanks in advance,
Beardking
