Results 1 to 6 of 6
Thread: Importing or Opening a Revit Model
    2011-03
    4
    Default Importing or Opening a Revit Model
    Hello
    Can I import or open a Revit model directly using Autocad, Navisworks, and 3D Max? If not what steps do I need to take?
    Brian.
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Default Re: Importing or Opening a Revit Model
    Not directly. Revit Files are RVT extensions. AutoCAD, Navisworks, and Max don't read RVT files natively. You will need to convert Revit files to DWG to be compatible in all three. Although you could make a DWG for AutoCAD, an NWC file for Navisworks, and an FBX file for Max.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2011-03
    4
    Quote Originally Posted by Scott Davis View Post
    Thanks Scott
    Do you know if Autodesk are looking at this option for any of these applications for the graphics only? I understand the information component might be a challenging task.
    Member jeremy.l's Avatar
    2010-02
    WA, Australia
    20
    I was under the impression that the flagship version of Navisworks has the capability to directly import .rvt files..
    RSnub.
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,257
    Quote Originally Posted by jeremy.l View Post
    I'd heard that, too. ~google~
    http://www.allthingsbim.com/2012/04/...orks-2013.html
    You can now merge RVT files directly from Navisworks without pre-exporting an NWC file from within Revit. This will probably be a true delight for builders who may no longer need an installation of Revit just to get the model data into Navisworks. Model components from a Revit model are now organized in the Selection Tree according to category, family, type, and instance.
    CAVEAT: This functionality will open the RVT file and will look for a 3D view for which the name contains “Navis.” If one is found, it will load the data that is visible in that view.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    Certified BIM Addict Brian Myers's Avatar
    2003-02
    Working in Cyberspace
    1,682
    Well, you have to examine the date at which this thread was originally answered (I believe about a week before Navisworks 2013 was released). With this latest release, direct opening of Revit files is finally available. To expand on that, 3DS Max 2013 can bring Revit files directly in as well.
    Here is a video on the process: http://www.youtube.com/watch?v=-8ryu61c7cs
    Brian Myers
    Sr Applications Engineer, Seiler Instrument | Autodesk Certified Instructor (ACI) Revit Architecture
    Creator of the Revit Users LinkedIn Community | Author of Revit Videos @ Lynda.com
  1. 2012: Importing Revit Arch model & levels
    By Damo in forum Revit MEP - General
    Last Post: 2012-03-07, 04:19 PM
  2. Importing RAM model
    By bellz in forum Revit Structure - General
    Last Post: 2009-08-27, 02:15 PM
  3. Importing a model from CSC to Revit Structure.
    By scott.billing in forum Revit Structure - General
    Last Post: 2008-09-29, 10:55 AM
  4. Importing Revit MEP Model
    By gelbrich in forum Revit Architecture - General
    Last Post: 2008-05-01, 10:02 PM
  5. Importing 3D dwg into Revit Model
    By s.messing in forum Revit Architecture - General
    Last Post: 2006-08-31, 06:15 PM
