Thread: FBK omits information
    2009-06
    11
    Default FBK omits information
    I have information in my RAW file that, when it is converted to a FBK, is omitted.
    My Raw file contains tree types and sizes, pipe sizes, benchmark and traverse information, etc. and once I convert it using Survey Link it is overlooked.
    Has this happened to anyone else? Is there another program I should be using to include this information? I need this information and it would be very time consuming to add it manually. Please Help!!!
    Thank you
    2010-10
    South Dakota
    37
    Default Re: FBK omits information
    Sounds like something is off, when I have imported direct from the DC I get the info.....presumably you have the tree size etc in the point code?
    2007-08
    23
    I take it you are talking only about the translation from raw to fbk and not the import into the survey module? Would you please post some lines from your raw file if possible and we can take a look.
  1. Replies: 8
    Last Post: 2021-08-26, 06:16 PM
  2. copy block and assign omits parameters
    By bmckenzie in forum Dynamic Blocks - Technical
    Last Post: 2009-09-17, 01:06 PM
  3. Too much information
    By tomdillenbeck in forum ACA General
    Last Post: 2004-08-20, 11:44 AM
