Results 1 to 1 of 1
Thread: Systems not connecting
    2007-04
    Ottawa, ON
    91
    Default Systems not connecting
    I've got a small little test file with some medical gas piping in it. A have a Zone Valve Box (Oxygen, Air, Vac) on the north wall that is serving 3 wall consoles (each having Oxygen, Air, Vac) on the south wall.
    On the ZVB I have 3 inlets coming in and 3 out the other side. I initially created the system with the 3 "in" connectors. Then right clicked the "out" connectors and used Add to System, clicked the ZVB family and then selected the appropriate system. I repeated this for the wall consoles (right click on connectors, Add to system).
    So all the connectors seem to be on the correct system, but when I go to pipe it up I get sections that are unassigned systems (show as black).
    Any ideas?
  1. How to: Not connecting two walls
    By cadorcl in forum Revit Structure - General
    Last Post: 2011-05-20, 12:39 PM
  2. Connecting to shp files with different coordinate systems
    By templedesignllc in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2010-04-20, 04:25 PM
  3. Connecting to a database
    By lambertm in forum VBA/COM Interop
    Last Post: 2008-09-17, 06:03 PM
  4. Connecting different networks??
    By whf in forum AutoCAD Civil 3D - Pipes
    Last Post: 2007-05-24, 04:44 PM
  5. Connecting beams
    By genbrugge_thomas in forum Revit Structure - General
    Last Post: 2007-04-12, 01:07 PM
