Thread: Content Browser Not Working
    2010-09
    8
    Default Content Browser Not Working
    I am using AutoCad MEP 2011...when I open my content browser to import a tool palette it is blank (see screen shot below). It will allow me to type in the search box, but it won't do anything else. I have tried running a repair...nothing. I installed the 2012 Trial...same problem. I had 2010 and upgraded to 2011, everything was working fine for several months...then my browser stops working...then some of my palettes disappear from the tool palettes menu.
    http://forums.augi.com/attachment.ph...1&d=1301583606
    Has anyone else experienced this problem? If so, how did you resolve it?
    2003-10
    Kettering, Ohio
    27
    Default Re: Content Browser Not Working
    I am having the same issue. I'm running AutoCad Architecture 2010 on a Windows 7 64bit machine. Has anyone had any luck fixing this issue? I would post a screen shot of mine but it is identical to yours. Help please! I need my content browser. I'm guessing it might be an Internet Explorer issue. I was running IE8, I thought from other research I'd done that IE might be the culprit so I updated to IE9, no changes.
    2010-09
    8
    ryant,
    Do you have multiple versions of AutoCad installed? I never did find a cure for the problem. I ended up uninstalling all previous versions of AutoCad from my computer, repair/reinstall in 2012, then everything came back and is still working great. I know it is not the solution anyone would like, but it's the one that worked for me.
  1. Replies: 0
    Last Post: 2013-05-05, 03:18 AM
  2. 2013: Content Browser i-drop not working
    By jaredk in forum ACA General
    Last Post: 2012-09-27, 07:31 PM
  3. Content browser I-drop not working
    By mferreri in forum ACA General
    Last Post: 2007-11-16, 04:15 PM
  4. ADT 2006 Content added to Content Browser does not stick
    By Marv Muston in forum ACA General
    Last Post: 2006-07-26, 12:11 AM
  5. Content Browser Not Working on Laptop
    By bsbad in forum ACA General
    Last Post: 2005-08-11, 12:45 PM
