Thread: kilowatts in piping.
    Member Gabriel Black's Avatar
    2006-10
    Antwerpen, Belgium
    33
    Unhappy kilowatts in piping.
    I'm VERY new to the Revit game and need help!
    Our engineers use the unit kW in the description of piping used for refrigeration purposes. The diameter of piping being governed by the unit.
    I haven't come accross the unit kW in Revit MEP at all and all our work is based mainly on this. How may I add or incorporate this on connectors for piping and the piping itself?
    Can it be done?
    Ciao for now.
    Gabriel Black.
    2006-05
    835
    Default Re: kilowatts in piping.
    Shouldn't you be looking at the Conduit tools?? Last time I checked liquid and electrical don't mix too well.
    I could be missing something however.
    AJS
    BIMM Consultant
    www.GHD.com
    2007-08
    13
    I suggest adding a shared parameter, choose "electrical" for the discipline (the default choice is common). Then select power which stores kW (Watt might be the default, in which case you need to configure your units to display in kW).
    GL
  1. 2012: Piping
    By sudarshankvarma007123670 in forum Revit MEP - General
    Last Post: 2012-02-09, 10:52 AM
  2. kilowatts in piping.
    By Gabriel Black in forum Revit MEP - General
    Last Post: 2011-04-06, 06:37 AM
  3. Piping, anyone?
    By Sheri_in_CA in forum AMEP Wish List
    Last Post: 2010-04-27, 04:21 PM
  4. Piping ISO BOM 3D
    By johan d in forum Software
    Last Post: 2006-05-02, 06:39 PM
