Results 1 to 9 of 9
Thread: Interior elevation key
    Active Member mrdavie's Avatar
    2010-06
    69
    Default Interior elevation key
    The interior elevation mark out of the box includes the name of the elevation, not simply the elevation number and sheet reference. I don't know how to get rid of the name of the elevation. Is there an alternate tag that someone can share with me?
    I tried to check on Revitcity (can I say that on this forum) but they are having access problems.
    David M. Rosen, RA
    Rosen Studio for Architecture
    david.rosen@rsfarch.com
    AUGI Addict cdatechguy's Avatar
    2004-02
    CdA, ID
    1,384
    Default Re: Interior elevation key
    What template are you using?
    This is from OOTB...Residential-Default.rte (2011)
    Michael "MP" Patrick
    "I never make stupid mistakes. Only very, very clever ones."
    2005-12
    566
    Find the elevation family in the Annotations section of your Project Browser. There's a switch for turning on and off names and numbers.
    2004-02
    CdA, ID
    1,384
    I think I edited the pointer and deleted out the elevation & view reference to make it easier....and then saved it back into the project.
    Currently I have our own company standard elevation....looks like our CAD version...
    I could stop if I wanted to nancy.mcclure's Avatar
    2007-05
    SF CA USA
    313
    mrdavie,
    You will find the settings to control what is reported under Manage > Additional Settings > Elevation Tags. Select the type that you want to use, and check the options from the pull-down list. (see attached image)
    These tags have a lot of 'hard-wiring' programmed into them, which is why then need to be modified this way, rather than as standard annotation tag families. Hope that helps!
    Nancy McClure, Assoc.AIA, LEED AP
    Aperte Design | Revit Strategist
    Revit Architecture 2011 x64 | Win7 x64 | NVidia GeForce G105M
    "It's not the strongest nor smartest that survive, it is the most adaptable to change." ~Charles Darwin
    2010-06
    69
    Thank you Nancy! You win the $10 iTunes gift card (not really) but you deserve one. Your answer solved my problem. I would have NEVER found it without your help.
    Here is another question. Is there a way to make the 1/2" circle a little smaller?
    David M. Rosen, RA
    2007-05
    SF CA USA
    313
    mrdavie,
    Yep, this is where it gets interesting.
    First, find the name of the .rfa that the tag is currently using for the elevation body (Manage > Addt'l Settings > Elev Tags > Elevation Mark Body_Circle (or similiar) THIS is the .rfa you need to duplicate/edit to change the circle radius. You'll find it where you installed your standard OOTB Imperial/Metric content.
    Load it into your project. If you simply modified the original and saved it, this will be updated automatically for you. If you duplicated the original, and renamed it, you'll need to set that new version in the Manage > Addt'l Settings > Elev Tags > [type].
    How's that Houston weather treating you?
    2004-02
    CdA, ID
    1,384
    Quote Originally Posted by nancy.mcclure View Post
    mrdavie,
    grrrr....I tried that before lunch and for some reason mine wouldn't change....thought something was wrong with the 2011 template.... Just tried it again and it worked
    2010-06
    69
    Clear, sunny, 79 deg
    David M. Rosen, RA
  1. 2012: Interior Elevation Tag
    By fputnam in forum Revit Architecture - General
    Last Post: 2011-12-30, 03:11 PM
  2. Jog In Interior Elevation
    By TerribleTim in forum Revit Architecture - General
    Last Post: 2010-08-12, 06:41 PM
  3. Interior Elevation Box
    By sjsl in forum Revit Architecture - General
    Last Post: 2007-08-02, 11:52 PM
  4. interior elevation tag
    By pcore in forum Revit Architecture - General
    Last Post: 2007-01-08, 02:32 PM
  5. Interior Elevation Tag
    By .chad in forum Dynamic Blocks - Technical
    Last Post: 2006-08-09, 08:35 PM
