Thread: How do I stop the 'Proxy Information' window opening each time I open up a drawing.
    Default How do I stop the 'Proxy Information' window opening each time I open up a drawing.
    Proxy Information (proxy graphics show/not show) window opens each time I open a existing drawing,
    How can I stop this window opening each time a drawing is opened.
    I am a AutoCAD 2010 user.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: How do I stop the 'Proxy Information' window opening each time I open up a drawing.
    You will need to change a setting within the Options dialog box. It can be found on the Open and Save tab under the ObjectARX Applications section in the lower right quadrant of the dialog box. More specifically, uncheck the "Show Proxy Information dialog box".
    This is also adjusted with the PROXYNOTICE system variable. It is most likely set to 1. Change it to 0 to disable the display of the proxy information dialog box. You should only have to do this one time on each machine you work on as this is a registry based setting.
    Cairo - no, not Illinois
    5,069
    or get the object enabler that's needed to display the objects that are being proxied.
  1. Open more than one drawing at a time?
    By billdinger in forum AutoCAD LT - General
    Last Post: 2007-07-16, 12:22 PM
  2. Replies: 10
    Last Post: 2006-10-11, 02:42 PM
  3. Wipeout Proxy Objects when opening drawing files.
    By LynNV in forum AutoCAD General
    Last Post: 2006-07-18, 05:50 PM
  4. AutoCAD Text window pops-up every time I open a drawing file.
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2006-05-08, 01:12 PM
  5. FATAL ERROR every time when Opening a certain drawing file
    By randyspear in forum AutoCAD General
    Last Post: 2006-05-08, 12:58 PM
