Thread: Default Viewport
    2007-10
    30
    Default Default Viewport
    When I hit the Layout1 tab, the paperspace window opens, and the default view shows up in it, which is the same view I had of my model in modelspace.
    Well, when I use the Viewport command to create new viewports, they appear over the default, and I can't get the default viewport to disappear.
    What am I doing wrong?
    This happens everytime I try to use paperspace, so I usually don't.
    -Ralphie
    0,0,0 The Origin
    8,570
    Default Re: Default Viewport
    You could open your normal template file, go to Options and uncheck the "create viewport in new layouts" box and save it. The default viewport won't be created.
    Have you tried deleting the default viewport before creating new ones?
    2007-10
    30
    Jaberwok, I tried the template trick and it worked! Thanks.
    I couldn't find how to delete the default viewport.
    Thanks again.
    Regards, Ralphie
    Cairo - no, not Illinois
    5,069
    select it as you would any other object, and delete it. if it's not selectable- check that all layers are on and thawed
  1. Replies: 2
    Last Post: 2017-08-09, 01:04 PM
  2. 2013: Default Viewport Style
    By jeff.95551 in forum Revit Architecture - General
    Last Post: 2012-11-14, 02:36 PM
  3. Viewport Title Default
    By Jrobker in forum Revit MEP - General
    Last Post: 2010-10-27, 11:45 PM
  4. Change the default viewport tag
    By jkipfer in forum Revit Architecture - Families
    Last Post: 2010-03-12, 11:52 PM
  5. Viewport-type default
    By B. Strube in forum Revit Architecture - General
    Last Post: 2005-11-14, 04:38 PM
