Thread: Conduit Bend Radius
    2004-06
    95
    Default Conduit Bend Radius
    I am having a problem using conduits and getting the radius to change and display properly. I am using the RMC Conduit without fittings and when there is a bend in the conduit Revit places a Conduit Elbow without fittings RMC Standard. I then select the elbow and change the radius but it doesn't update graphically.
    Another user in our office does the same thing I am doing and using the same families and he can get it to display correctly. See attached.
    Any thoughts or workarounds?
    I am new to Revit MEP but know Revit Architecture.
    Jason
    2007-09
    490
    Default Re: Conduit Bend Radius
    The second screen shot shows that the path to the lookup tables is incorrect. Lookups used to only affect pipe fittings, but starting in RMEP 2011, they became responsible for the conduit fittings as well. Check your file path in the Revit.ini
    Also, the bend radius is controlled via "Electrical Settings." Under Conduit Settings, click "Size" and you will be able to adjust the bend radius for each conduit type.
    2004-06
    95
    Thanks. The path was incorrect.
  1. 2013: Cable Tray Fitting bend default radius
    By ftonelli in forum Revit MEP - Families
    Last Post: 2017-10-13, 09:40 AM
  2. 2011: Anyone knows how to change several conduit bend radius globally?
    By yuhonggao758424 in forum AMEP General
    Last Post: 2013-07-24, 01:11 PM
  3. 2013: Pipe fitting - bend radius
    By desandli836892 in forum Revit MEP - Families
    Last Post: 2013-02-19, 01:39 PM
  4. Changing the radius of a Conduit/Pipe bend
    By pirit4 in forum ACA/AMEP Tutorials
    Last Post: 2010-03-05, 02:43 PM
  5. Dynamic radius bend
    By stephen.coff in forum Dynamic Blocks - Technical
    Last Post: 2005-12-22, 05:37 PM
