Thread: Anyone knows how to change several conduit bend radius globally?
    2011-04
    Question Anyone knows how to change several conduit bend radius globally?
    I am working on a drawing which I would like to change the radius of the conduits bend parts, is there anyway I could just select all of the conduits bend parts, then I could change the radius of curvature R1 for all of bend parts in one go? It seems that MEP only allow me to change the radius of curvature R1 individually which is quite time consuming, anybody knows, very appreciated... Unfortunately property match doesn't work in this case...
    Amanda
    ACA/AMEP Community Chair stelthorst's Avatar
    2003-10
    San Francisco CA
    1,190
    Default Re: Anyone knows how to change several conduit bend radius globally?
    Hi Amanda,
    Unfortunately I don't know of a way to globally change existing conduit bends. However, if you have a requirement to use specific radius bends for a project you might want to create a bend style.
    WARNING: I strongly suggest that you save a copy of the out-of-the-box (OOTB) catalog before making any modifications so that you can return to this if an error occurs in your new catalog.
    NOTE: My current project requires AMEP 2008 so some of the items I describe may not apply or may be different than my screen shots for newer versions.
    Now on to the fun,
    1. Go to the catalog editor and open your newly created conduit catalog.
    2. Open the conduit type you want to modify. (In my example EMT set screw connectors) See Figure 1 attached.
    3. You should be able to copy and paste the standard radius bends and rename it.
    4. Go to the calculations module and change the R1 radius to what you want. See Figures 2 and 3.
    5. Now that you have a new style you can click an individual bend and change the conduit fitting style. See Figures 4, 5, and 6.
    6. Additionally, you can change the conduit preferences to your newly created style to make all the newly crated bends on the drawing in this style. See Figure 7.
    I recognize that I have given very little information but play with it a bit and post back with any problems/questions you may have.
    Hope this helps,
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    Some see the glass as half full, others as half empty. As an engineer I see the glass as twice as big as it needs to be. ~Unknown~
    2011-04
    Thanks, Scott ~ this might help~
    2011-04
    error.docxHi
    I have been working on this project by using autocad mep 2013 which my computer was just upgraded to, I found that i am not allowed to modified the conduits bend radius, it is so frustrating...i tried to open catalog editor and modified it and it didn't work, i think i have messed up this.
    1st question: how could I back to default setting?
    2nd question: where it went wrong?
  1. 2013: Cable Tray Fitting bend default radius
    By ftonelli in forum Revit MEP - Families
    Last Post: 2017-10-13, 09:40 AM
  2. 2013: Pipe fitting - bend radius
    By desandli836892 in forum Revit MEP - Families
    Last Post: 2013-02-19, 01:39 PM
  3. Conduit Bend Radius
    By ajtrahan in forum Revit MEP - General
    Last Post: 2011-04-11, 08:04 PM
  4. Changing the radius of a Conduit/Pipe bend
    By pirit4 in forum ACA/AMEP Tutorials
    Last Post: 2010-03-05, 02:43 PM
  5. Dynamic radius bend
    By stephen.coff in forum Dynamic Blocks - Technical
    Last Post: 2005-12-22, 05:37 PM
