Results 1 to 9 of 9
Thread: Horizontal angle of rotated vertical bend
    2011-04
    4
    Unhappy Horizontal angle of rotated vertical bend
    Does anyone have a routine to calculate the horizontal angle of a bend (11 1/4, 22 1/2, or 45) given the required vertical angle (or vice-versa)?
    I've spent a lot of time trying to figure it out on my own but my math skills just aren't strong enough.
    All AUGI, all the time marko_ribar's Avatar
    2015-10
    Belgrade, Serbia, Europe
    525
    Default Re: Horizontal angle of rotated vertical bend
    I must admit, I don't quite understand what angles are you mentioning. Can you attach sketch of your question?
    M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on Youtube
    2011-04
    4
    Assuming the pipe in the attachment is a vertical bend (i.e. water main, gas line), if you rotate it along the axis formed be the horizontal section, the section moving diagonally up will flatten and you will create a horizontal bend. In those cases where it's advantageous to achieve a non-uniform vertical bend (something other than 11-1/4, 22-1/2, or 45 degrees), you could rotate the bend down but you would need to know what the resulting angle would be in plan view.
    2015-10
    525
    1 members found this post helpful.
    If I understood correctly, you don't know how to obtain angle of projection on plan view of bend that was rotated along horizontal axis down by alpha degree starting from vertical position of 90 degree... If you look from side where axis of rotation is viewed in special position as point, you will see bend as line that when rotates makes circle... If you rotate from vertical position by alpha, your horizontal projection would be L*cos(alpha), vertical L*sin(alpha), where L is projection length of bend in our special projection view, and if bend is bended at 45 degree as shown in attached file, after some calculations, I've found :
    (defun c:hpa-ra () (c:hprojang-rotang) )
    (defun c:hprojang-rotang ( / alpha gamma gammar)
    (setq alpha (getangle "\nInput angle in decimal degrees for rotation of bend along main pipe axis : "))
    (setq gammar (- PI (atan (cos (- (/ PI 2) alpha)))))
    (setq gamma (* (/ 180 PI) gammar))
    (princ "Horizontal projection angle is : ")(princ gamma)(princ " degrees")
    (princ)
    (princ "\nType \"hpa-ra\" for shortcut")
    (princ)
    This only works for bend of 45 degrees...
    This works for all curvatures of bend pipes :
    (defun c:hprojang-rotang ( / alpha beta v-h gamma gammar)
    (setq beta (getangle "\nInput angle in decimal degrees for curvature of bend of pipes : "))
    (setq v-h (/ (sin beta) (cos beta)))
    (setq gammar (- PI (atan (* v-h (cos (- (/ PI 2) alpha))))))
    (princ)
    (princ)
    M.R.
    Last edited by marko_ribar; 2011-04-19 at 11:53 AM. Reason: adding additional code
    M.R. on Youtube
    2011-04
    4
    Well, I think you're on the right track but I need something that will work for 11-1/4 and 22-1/2 degree elbows as well. Also, the results, while correct, are confusing.
    Thanks for the effort!
    2015-10
    525
    I did it for all elbow angles...
    You didn't see additional code...
    M.R. on Youtube
    2011-04
    4
    Oh. Sorry...
    Thank you very much. You've saved me a lot of time. Not from trying to figure this out; I couldn't. You've saved me from having to manually create a 3D part, manually rotating it, and measuring the new horizontal angle. All through trial and error.
    Thanks again!
    2017-03
    Quote Originally Posted by marko_ribar View Post
    (princ)
    (princ)
    (princ)
    (princ)
    M.R.
    Okay so I have the lisp routine up and running but I do not understand the input parameters. Can someone break it down for me?
    2015-10
    525
    Analyze attached picture to see what angles alpha, beta and gamma are...
    M.R. on Youtube
  1. 2014: Cable Tray/Ladder Rack Horizontal Bend 3D Surfaces
    By Brendan H in forum Dynamic Blocks - Sharing
    Last Post: 2015-09-20, 03:36 PM
  2. Tile Horizontal / Vertical
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2015-01-30, 01:01 PM
  3. 2014: Etiquette allège dans un angle autre que horizontal ou vertical
    By batproj in forum Revit Architecture - Général
    Last Post: 2013-10-21, 04:56 PM
  4. Targeting Vertical before Horizontal
    By JTH-ABAM in forum AutoCAD Civil 3D - Corridors
    Last Post: 2011-12-13, 12:46 AM
  5. snapping horizontal or vertical
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2006-07-24, 10:29 PM
