Results 1 to 10 of 10
Thread: Bottom of pipe elevaion tag
    2016-01
    44
    Question Bottom of pipe elevaion tag
    hi,
    I want to tag bottom elevation of Pipe ,but I am not find out bottom elevation parameter in Pipe tags family categories & parameters(which is present in Duct tag categories).
    The invert elevation tag parameter tags the elevation in relation to level 0 and currently I am working in -10 meter level.
    spot elevation also tag the pipe with relation to level 0.
    start offset & end offset parameter tags the center elevation of pipe.
    Is there any option in Revit MEP 2011 to place bottom of pipe elevation tag in any level?
    Any input would help.
    Thank you
    Regards
    Swapnil
    2004-06
    Port Moody, BC
    349
    Default Re: Bottom of pipe elevaion tag
    You can set the spot elevation tags to show a relative elevation (relative to the view) in the Type properties of the tag (as per attached image). You will need to set the view to Fine and Wireframe to get the tag to pick your pipe correctly I think.
    Last edited by drewj; 2011-04-25 at 04:22 PM. Reason: added spot to the tag name type
    2009-08
    62
    I built an add-on tool to achieve this. It auto tags the pipes at high and low ends. Have demo if interested...
    2009-02
    Quote Originally Posted by nwecksler View Post
    How to make it (tag)? Please.
    2009-08
    62
    2012-05
    please if it avilable i need this demo file please urgently
    2015-11
    Saint Louis, MO
    485
    N8wex,
    i installed your add-in just to see what it did, now i get an error (Demo vesrion can only be used in file 'InvertLevel Standard Demo.rvt') every time i click a pipe.
    how do i uninstall or get rid of this add-in? i can't find it in the uninstall programs list nor the revit.ini file.
    2004-06
    Port Moody, BC
    349
    Quote Originally Posted by mhartmann View Post
    N8wex,
    I dont know about this one in particular, but in general the add-ins are registered via a .addin file located in the following folder:
    C:\ProgramData\Autodesk\Revit\Addins\2013\
    If you remove this addin file it wont load (the addin file is an xml type file that will give you the name and location of the dll being referenced too).
    I would start here, of course as a programmer the maker of the demo could have done all kinds of fancy things...
    2015-11
    Saint Louis, MO
    485
    Fixed! thanks Drew!
    2012-06
    3
    How can we get the tool. When we go to this link (http://dl.dropbox.com/u/8875196/Inve...20-%20Demo.exe) then we are getting the blow mentioned error:
    Restricted Content
    This file is no longer available. For additional information contact Dropbox Support.
    Please suggest. Thanks in advance!
  1. 2015: Dynamo to get the Bottom of Pipe tag
    By icesalt4682576 in forum Dynamo - API
    Last Post: 2015-07-14, 02:26 PM
  2. Allow dragged pipe labels to go to the top or bottom of the pipe
    By chris.safford in forum Civil 3D Wish List
    Last Post: 2013-04-29, 10:02 PM
  3. Show only top or bottom of pipe in Profile?
    By jetomlinson in forum AutoCAD Civil 3D - Pipes
    Last Post: 2010-09-02, 09:26 PM
  4. Bottom of Pipe Tag?
    By jhenry in forum Revit MEP - General
    Last Post: 2009-12-15, 06:29 AM
  5. Bottom of pipe dimension tag?
    By sgermano in forum Revit MEP - General
    Last Post: 2008-01-21, 08:47 PM
