Results 1 to 7 of 7
Thread: AutoLISP for automatically drawing second dimension of rectangle based on first dimension
    2008-12
    3
    Default AutoLISP for automatically drawing second dimension of rectangle based on first dimension
    Good morning group,
    I am trying to write a LISP routine that will generate a rectangle based on the first input dimension always with the proportion of 1:1.618. If anyone can help I would certainly appreciate it.
    2009-11
    5,719
    Default Re: AutoLISP for automatically drawing second dimension of rectangle based on first dimension
    Try this:
    (defun c:SREC ( / pt h)
      (princ "SPECIAL RECTANGLE ")
      (if (and (setq pt (getpoint "\nSpecify rectangle start point: "))
               (setq h (getreal "\nEnter the rectangle length: ")))
        (command "._rectang" pt "_dimensions" (* 1.618 h) h pt)
        (prompt "\n** Invalid input ** "))
      (princ))
    Computer Specs:
    2008-12
    3
    Renderman...worked perfectly..Thank you very much for the code....will certainly help in design process.
    Cheers,
    Richard
    2009-11
    5,719
    Quote Originally Posted by rjperkin View Post
    You're welcome, Richard.
    Cheers!
    Computer Specs:
    2015-10
    Belgrade, Serbia, Europe
    564
    You probably wanted golden number fi...
    To be more precise :
    (defun c:GREC ( / pt h fi)
      (princ "GOLDEN RECTANGLE ")
               (setq h (getdist pt "\nEnter the rectangle length: "))
               (setq fi (/ (+ (sqrt 5) 1) 2)))
        (command "._rectang" pt "_dimensions" (* fi h) h pt)
      (princ))
    M.R.
    2009-11
    5,719
    Quote Originally Posted by marko_ribar View Post
      (princ))
    M.R.
    Yes, I believe you are correct MR - I should have caught that given the explicit number requested.
    Phi = fi LoL
    I :heart: Quadratic Equations.
    Computer Specs:
    2008-12
    3
    Gentlemen,
    Yes, Golden Rectangle is what I was looking for. Did not know how to code it as I am only standing by the ocean of Visual Basic and watching the AutoLISP routines go by!
    Thanks again to you both,
    Richard
  1. Dimension multiple lines automatically
    By cormac.mcgavigan516711 in forum AutoLISP
    Last Post: 2011-12-06, 12:58 PM
  2. dimension scale is automatically overridden
    By lcarignan in forum AutoCAD General
    Last Post: 2008-09-19, 09:43 PM
  3. Automatically calculate each room dimension in schedule
    By bradylady in forum AutoCAD Customization
    Last Post: 2007-11-21, 02:05 PM
  4. Replies: 9
    Last Post: 2006-07-29, 07:48 AM
  5. Dimension Text Override with Autolisp
    By CADdancer in forum AutoLISP
    Last Post: 2005-07-12, 05:33 PM
Tags for this Thread
