Results 1 to 10 of 12
Thread: old .dwgs lineweight and color issues
    2010-08
    17
    Unhappy old .dwgs lineweight and color issues
    In the process of getting the company I work for updated to AutoCAD 2012 I have encounter a strange display issue. some of my old drawings react normally, but others show strange display behavior. The issue is that some drawing will display as a single color (gray). However if I chcange the visual style to anything other than the default of "2D Wireframe" the correct layer colors appear. There is another number of .dwgs that appear in the proper color, but the linw weight displayed is so heavey that you can't read the text. These issues are solved by copying and pasting the entites into a new drawing, but that is not a very friendly solution. i have compared variables and setting, but cannot find a common denominator. Any help is appreciated,
    Thanks in advance.
    2001-12
    St. Louis
    5,408
    Default Re: old .dwgs lineweight and color issues
    I'd recommend first checking the LWDISPLAY system variable and setting it to OFF, if it's not already.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2010-08
    17
    Tnaks for the quick response, and I checked that variable, but sadly it is already off.
    Cairo - no, not Illinois
    5,069
    Audit the drawings, and/or Recover them?
    2010-08
    17
    I have run audits and they return no errors.
    2005-06
    in the upper right corner
    3,508
    Just a thought, on the ones that are effected;
    Do you have "Display Plot Styles" checked on?
    (and do you have the correct plot styles assigned to them?)
    This will make them appear as they would be plotted, given the plot style that is assigned to the layout.
    Look into your Page Setup Manager on those drawings to be sure.
    Hope that helps
    2010-08
    17
    Bingo!! Almost there.
    Now how do I automate the removal of the check from that setting.
    Thank you Ted.
    2005-06
    3,508
    Quote Originally Posted by kfreitag View Post
    Thank you Ted.
    Maybe THIS THREAD will help.. sort of.
    This was asking to have the plot style display on (not off)
    2005-06
    3,508
    After looking at that routine, I modified it to meet your reqest, if you place this code in your acaddoc.lsp it will turn off the "display plot styles" in every drawing you open.
    (defun showpstyle ( / DOC LAYOUTS)
      (setq doc (vla-get-activedocument (vlax-get-acad-object))
            layouts (vla-get-layouts doc)
            ); setq
      (vlax-for n layouts
        (vl-catch-all-apply 'vla-put-showplotstyles (list n :vlax-false))
        ); vlax-for
      (vla-regen doc acAllViewports)
      (mapcar 'vlax-release-object (list layouts doc))
      (princ)
      ); defun
    (showpstyle)
    2010-08
    17
    Here is the error i get with that code: "; error: no function definition: VLAX-GET-ACAD-OBJECT"
    I'm guessing that the VLAX functions are part of another addin.
  1. 2015: Lineweight Issues with AutoCAD 2015
    By mccurleyd691347 in forum AutoCAD General
    Last Post: 2015-02-23, 05:38 PM
  2. Assign Lineweight per color not layer
    By fcfcadd in forum AutoLISP
    Last Post: 2008-05-14, 03:18 PM
  3. stb dwgs lineweight control in revit
    By D_Driver in forum Revit Architecture - General
    Last Post: 2006-08-14, 06:19 AM
  4. Footing lineweight issues
    By jmctamney in forum Revit Structure - General
    Last Post: 2006-02-28, 05:21 PM
  5. Replies: 16
    Last Post: 2005-01-20, 05:38 PM
