Results 1 to 6 of 6
Thread: Metric Steel Framing and Columns
    2009-01
    57
    Default Metric Steel Framing and Columns
    I'm trying to find a place to download the Metric Steel database for Revit. I've already changed the units and created dimensions. Is there a place to get this file from, and if so, is it really as easy as just importing it? Thanks
    2010-04
    109
    Default Re: Metric Steel Framing and Columns
    Why do you need to download the metric library? When you install Revit, choose a country with metric units and Revit will download the library automatically.
    Also, you can check:
    http://cadalot-revitlearningcurve.bl...evit-2012.html
    It seems that you have to install US Metric to find what you need.
    2009-01
    57
    The problem is that for the majority of our jobs we use the Imperial Library. We just started working on a project where everything is in metric including the shapes. So, I was hoping that it was possible to download the metric library files outside of the initial install of Revit and therefore apply it to a template for future jobs of the same type.
    2007-01
    226
    My install of Revit Structure 2012 (US version) installed both US Metric and US Imperial Libraries.
    My install of 2011 (US version) only had US Imperial Library.
    2008-11
    Australia
    754
    http://usa.autodesk.com/adsk/servlet...12&id=14974219
    Download the library appropriate for you. Also, make sure you use the unpack contained in there that retains the file structure, or be prepared to spend a good day sorting your families out.
    2009-01
    57
    Thumbs up Re: Metric Steel Framing and Columns
    Yes, I'm still using 2011 as my employer just received the 2012 version. What we had to do was simply install a trial version of Revit on another computer, select a metric region, and then copy over the metric library (which took about 20 minutes) next to our imperial library.
  1. Steel Framing Schedules - A & W
    By ckeelor in forum Revit Structure - General
    Last Post: 2009-11-04, 01:37 PM
  2. Metric Steel Sizes for SP3
    By djn in forum Revit Structure - General
    Last Post: 2008-02-14, 12:53 PM
  3. Architectural - Steel Framing
    By bshank.140587 in forum Dynamic Blocks - Sharing
    Last Post: 2007-08-24, 05:36 PM
  4. Steel Framing
    By barathd in forum Revit Architecture - General
    Last Post: 2005-05-17, 03:31 AM
  5. Steel Framing
    By gj in forum Revit Architecture - General
    Last Post: 2004-02-10, 08:00 AM
